Home > Help Needed / General Tech Chat > Rollcage
turbominij
Member #: 2104
Essex - UK
just wondering which is better or if there is much difference between 5 and 6 point cages?
the 5 point bolts to the rear shelf.
"Tuning should be a compromise between what is possible and what is necessary"
10)Thou shalt always quest for more power
The rear shelf is in no way structural and would need serious strenghtening before using it as a loadbearing point for the cage.
turbominij
Member #: 2104
Essex - UK
would it be worth using it as well as the normal 6 point positions?
I believe Wil's post answers this question.
Useful for ballast to make sure your C of G is as high as possible only IMO.
turbominij
Member #: 2104
Essex - UK
ok thanks for the advice wil_h
will keep an eye out for a 6 point then.
i had not seen anyone using a 5 point so thought id ask and now i no why not.
