| Home > Help Needed / General Tech Chat > Water cooling the GT1752 | |||||||
24th Jan, 2011 at 08:39:02pm
What size pipes are all you out there using for the water supply and return ?
24th Jan, 2011 at 10:15:57pm
Im using 8mm on the feed and return on mine Dave. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
![]() 489 Posts Member #: 9159 Senior Member Devon |
25th Jan, 2011 at 12:49:10am
sliiight hi-jack but saves me making another topic:
25th Jan, 2011 at 06:07:48am
I,m using banjos, but I would have thought the brass fittings illustrated would be available from a plumbers supply place. The thread is 14mmx1.5 if you dont already know but Robert seems to have used a tapered thread item, going by the lack of sealing washers.
![]() 864 Posts Member #: 951 Post Whore Bromsgrove |
25th Jan, 2011 at 07:59:07am
Hi David,mine's 8mm as well.I break into the return from the heater matrix for supply and return,just don't turn the heater tap off! 'Where does the engine go?' |
25th Jan, 2011 at 09:10:39am
Im using an electric pump on mine, but its the equivalent of the feed coming off the bottom rad hose and the return goes to the top of the rad. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
25th Jan, 2011 at 10:43:57am
Thats what I thought Steve -thank you
25th Jan, 2011 at 01:19:51pm
I have the banjo ends of the SAAB pipes, and from memory they are 8mm OD.
