| Home > Help Needed / General Tech Chat > megajolt , which one ? | |||||||
337 Posts Member #: 9138 Senior Member wolves |
26th Jan, 2011 at 07:35:18pm
which one do i need for std metro turbo in a mini ? tried the search and got lots of info but want to be sure i get the right one .
26th Jan, 2011 at 08:04:51pm
You need to make sure it's the MAP version, rather than the TPS one for a Turbo install. |
![]() 489 Posts Member #: 9159 Senior Member Devon |
26th Jan, 2011 at 08:36:14pm
silly question: so with the MAP version, theres no need for trigger wheels etc? |
26th Jan, 2011 at 08:39:50pm
still need the wheel,
26th Jan, 2011 at 08:41:47pm
MAP = manifold Air Pressure. Nothing to do with the trigger wheel. The trigger wheel measures the crank angle to time the spark angle. The MAP measures the pressure / vacuum to gauge the load on the engine. The matrix of MAP v RPM is the ignition map.
http://www.twin-turbo.co.uk
