| Home > Help Needed / General Tech Chat > Starter motor from 988cc to metro turbo 1275cc | |||||||
289 Posts Member #: 8160 Senior Member , mitcham, surrey, london, cr4 |
26th Jan, 2011 at 07:40:48pm
hi there
Nothing special! |
26th Jan, 2011 at 07:46:57pm
as long as they are the same type it should fit On 11th Feb, 2015 robert said:
26th Jan, 2011 at 08:02:05pm
I was thinking to buy new one, but Which one I need? pre-engaged or inertia ??
Nothing special! |
26th Jan, 2011 at 08:11:30pm
On 26th Jan, 2011 apbellamy said:
as long as they are the same type it should fit Nothing special! |
26th Jan, 2011 at 09:52:46pm
There are basically two different types, inertia and pre-engaged.
26th Jan, 2011 at 11:18:54pm
ok, now i am bit smarter On 26th Jan, 2011 wil_h said:
There are basically two different types, inertia and pre-engaged. The preengaged has the solenoid on it the inertia has the solenoild on the inner wing. As long as you are swopping like for like then it makes no differance between 1275 and 998. As far as bhp is concerned it makes no differance. Incact a low compression turbo will be easier to spin over than a standard motor. Lightened flywheels are available for all starters, so no worries which one you have. Nothing special! |
