Home > Help Needed / General Tech Chat > Metro t gearbox
andyuk1275
Member #: 9276
Darlington north east
Hi all.
Will a mertro gearbox fit straight to a 1275 a+ engine?
Thanks
Rick.SPI
Member #: 8027
its prettymuch the same gearbox mate.
Edited by Rick.SPI on 28th Jan, 2011.
if its a genuine turbo box, it will have a larger nose bearing, meaning you'l need to use the transfer case also,or justchange the bearing......
andyuk1275
Member #: 9276
Ah right thank lads, I'm running a 1275 a+ and have a t2 turbo Will the garbox put up with 12 psi standard ?
turbominij
Member #: 2104
Essex - UK
im running 12psi just under 120bhp at the wheels on a standard turbo box and std drops, only thing i have changed in it is the diff, to an x-pin diff which is a must for that power!!
it has been fine for the last 2 years
if however you plan to wheelspin eveywhere and launch it hard all the time you might come a cropper
Edited by turbominij on 28th Jan, 2011.
"Tuning should be a compromise between what is possible and what is necessary"
10)Thou shalt always quest for more power
As a minimum I would replace the diff with a 4 pin one. The factory ones are a big weak point.
We're putting about 150bannas through a standard helical box and so far it has taken it.
IMO, bearing condition is as important as the condition of the gear set.
My one has only just recently turned to dust, and thats a 66k mile engine, at standard-ish boost....
Good thing i have a spare S/C box.....
