Home > Help Needed / General Tech Chat > Cam Timing
ERA ANT
Member #: 4179
Cumbria
Hello all. I am in the process of rebuilding my metro turbo engine and i am fitting a MED T3 cam. Do any of you know what the degree full lift should be on no1 inlet?
Do it right the first time and make it mint!!!!!!
hi ant, you should have got, a spec sheet with the cam, if not ring med up.
T3 sounds a little wild on duration? are you tracking the car?
when you get the spec, could you post the info up please.
ERA ANT
Member #: 4179
Cumbria
T3 is MED's 1st uprated turbo cam. They do a T5 cam but i thought that would be abit lumpy for road use. I will phone them on monday and gt the spec as ther wasnt a spec sheet in with the cam. Yes i will post up the info to. 8-)
ERA ANT
Member #: 4179
Cumbria
Full lift on no1 inlet 110 degrees after tdc.
do you have the cam spec details lift duration ...etc ?
