| Home > Help Needed / General Tech Chat > gearbox,CR questions | |||||||
107 Posts Member #: 9276 Advanced Member Darlington north east |
30th Jan, 2011 at 09:50:49pm
Hi yet again all.
30th Jan, 2011 at 09:56:33pm
drop gears is a tricky one, I have destroyed std drops at only 80 hp, however robert on here is using std drops at circa 200hp reliably.
30th Jan, 2011 at 09:56:36pm
Edited by Joe C on 30th Jan, 2011. On 28th Aug, 2011 Kean said:
30th Jan, 2011 at 10:45:34pm
On 30th Jan, 2011 andyuk1275 said:
Hi yet again all. This is my first turbo conversion so please be patient will all the questions :). On an A+ 1275, will i need straight drop gears at 12 psi? I've already clarified i need a cross pin diff. I've been studying compression ratios all night and i still cant come to terms with it. am i right i thinking if i get the head re bored say 0.020" i need pistons that are 0.020? what does cc mean when it comes to the piston dish? how does V+C divided by C give me 8.5-1? thanks for all the help its really appeciated ! Good quality cross pin diff is a wise idea. I ran std drops for approx 100k at around 21psi over 3 years way back when my mini was my daily driver. Never had any issues despite going through several A+ gearsets, and some straight cut gears and a couple of diffs Compression ratio http://www.csgnetwork.com/compcalc.html 9.85 @ 145mph
![]() 514 Posts Member #: 2104 Post Whore Essex - UK |
30th Jan, 2011 at 11:28:42pm
I run 12psi on STD drops and gearset and has been fine for 3years+ "Tuning should be a compromise between what is possible and what is necessary"
