| Home > Beginners Tech > changing diff ratios | |||||||
547 Posts Member #: 2928 Post Whore peterborough |
30th Jan, 2011 at 11:57:16pm
hi guys,
Jack Jones |
31st Jan, 2011 at 07:37:09pm
if the inner race is tight, I usually use a bit of heat and the 2 arm puller on the bearing splitter although you could use levers. I generally don't re-use them though as the heat normally affects the cage |
31st Jan, 2011 at 08:06:04pm
Put a cold chisel between the crown wheel and the bearing On 11th Feb, 2015 robert said:
31st Jan, 2011 at 11:50:15pm
Ok lovely job guys, is a press required for fitting the bearings as they are sounding a little bit like wheel bearings
Edited by just_jack on 31st Jan, 2011. Jack Jones |
1st Feb, 2011 at 07:39:11am
1st Feb, 2011 at 08:06:08am
no need for a press to fit |
1st Feb, 2011 at 09:50:48am
Press makes it easy, a big vice will do it though, or hammer and drift.
1st Feb, 2011 at 12:53:17pm
Thanks guys, i will get involved, I take it it will need some good force then no pansy-ing around with getting it off
Jack Jones |
1st Feb, 2011 at 12:55:14pm
I've had one that was a PITA the get off once. Bit naughty but I put a crow bar down the back and it just slid off with that! If something is worth doing, it's worth doing half of. |
![]() 509 Posts Member #: 1027 Post Whore Germini, black forrest |
1st Feb, 2011 at 01:20:03pm
One I had needed the oxy burner and TWO crowbars to get it off [X] nail here for new monitor |
