| Home > Beginners Tech > megajolt v4 or v4e | |||||||
![]() 190 Posts Member #: 8935 Advanced Member netherlands |
1st Feb, 2011 at 07:13:38am
Hi all,
90 Posts Member #: 7555 Advanced Member |
1st Feb, 2011 at 01:05:17pm
From memory the 'E' version does the same as the non-'E' version but uses components that aren't suitable for DIY assembly which is why you can only buy it fully built now.
![]() 257 Posts Member #: 7048 Senior Member Bridgend |
31st Mar, 2011 at 02:17:15am
It's pretty much as Midas has said, but if your a berk like me and damage the unit, you can't repair it yourself. Other wise they work the same, the plugs are the same aswell, when I broke mine, I just plugged a normal v4 in. Turbo parts collector at the moment, almost ready. |
6 Posts Member #: 9445 Junior Member |
21st Apr, 2011 at 08:06:31pm
One of the other reasons for the difference is that Fresscale (makers of the MCU in the Megajolt) keep EOL'ing the chips. The makers of MJ decided to go surface mount to cut down on the number of returns that looked like they had been soldered with a hot shovel.
