Home > Ebay items For Sale > Couple of GT17s (not mine)
DaveVader
Member #: 9075
Peterborough
I may have got it right this time, they don't seem to be Chinese copies.
One here and here.
He's got a few, and a shop selling Saab parts.
Seem to be fair prices (depending on condition) and I've asked him if they're genuine and not Chinese copies.
I suspect they are proper Garrett items but it's always worth an ask.
I'll ask him a question about shaft play (I believe that is a service he offers) and then possibly pick on up (if I can afford it).
If I'm the first to go for it I'll post up whether it seems to be worth it on first inspection.
tadge44
Member #: 2500
Buckinghamshire
I,v bought stuff from this guy before and I have no doubt that these are Garrett turbos.
If you do go to pick one up see if you can get the alloy cast inlet for the compressor as it makes it easier to connect(its a V band arrangement) -also see if he will let you have the first few inches of the exhaust for the same reason.
DaveVader
Member #: 9075
Peterborough
aye, he confirmed they were Garrett items.
I've already spent so much this month but it's tempting! I'll drop him a message, see what he says about the inlet for the compressor and the exhaust.
yes i have had bits off him give him a call top lad.
chominsh
Member #: 8160
, mitcham, surrey, london, cr4
can any one advice what i will need else (where can i buy it) to convert from stn T3 to this turbo???
Nothing special!
you will need -
1. GT17 turbo (new or old ebay, saab breakers so on)
2. outlet manifold (make it / buy one off matty / have a search on here at what some have done
3. You will need to make a down pipe (as they can not be bought yet)
4. oil feed
and i have found all this out from reading lots on hear mate, have a search around look for words like GT17, gt 17, oil feed, oilfeed, how to, convert,
hope this helps simon.
Edited by madmk1 on 2nd Feb, 2011.
tadge44
Member #: 2500
Buckinghamshire
Add to that the oil return and water pipes which you will need to make.
Also, unless you but one of Matty,s manifolds you will need to modify the turbo to fit the Metro/T3 manifold
Thats lot of money for an old turbo.
DaveVader
Member #: 9075
Peterborough
Depends on condition, cheapest I've found for a genuine Garrett GT17 and I've been hunting a fair bit recently.
DaveVader
Member #: 9075
Peterborough
He has a new one for 390 squid aswell.
