| Home > Help Needed / General Tech Chat > Different turbos help needed. | |||||||
162 Posts Member #: 9342 Advanced Member Southern Norway. |
1st Feb, 2011 at 02:16:47pm
Hi all, this is my first post on this forum :)
1st Feb, 2011 at 02:25:57pm
I'd go for the GT1752 as it seems to be capeable of pretty much anything! lol
1st Feb, 2011 at 02:28:10pm
hehe, sounds good, i checked some threads with gt17, and heard stuff as turbo lag, and that it was to big for 140bhp, and the boost coming to slow. Is this true? :) |
1st Feb, 2011 at 02:43:03pm
From memory i read that one user was getting "some" boost from as little as 1500rpm! If something is worth doing, it's worth doing half of. |
1st Feb, 2011 at 02:45:39pm
wow, ok i will definitely go for that one then :p thx a lot for great answers! :) |
1st Feb, 2011 at 02:48:47pm
Don't take what I say as gospel. Have a good rummage around this site and also wait for other replies. However I think its fairly safe to say you won't be disappointed with the GT17.
1st Feb, 2011 at 05:18:01pm
Hehe, sounds great to me =)
1st Feb, 2011 at 10:12:32pm
Sorry, i meant 430£ :] |
![]() 1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
1st Feb, 2011 at 10:14:57pm
it is if its not a copy of the original. On 17th Feb, 2011 apbellamy said:
I popped my first one out the other day... |
289 Posts Member #: 8160 Senior Member , mitcham, surrey, london, cr4 |
2nd Feb, 2011 at 12:14:44am
On 1st Feb, 2011 Utking said:
Sorry, i meant 430£ :] Nothing special! |
2nd Feb, 2011 at 07:41:32am
Starts building boost and making useful boost are quite different things. Roberts car is remarkable, but it is not making propper boost at 1500rpm.
2nd Feb, 2011 at 08:19:33am
^ See told you not to listen to me :) If something is worth doing, it's worth doing half of. |
2nd Feb, 2011 at 08:34:54am
heres my engine boost curve from the gt 17 thread ...,this was set to 5 psi .
2nd Feb, 2011 at 08:53:49am
Exactly. at 2k you have 1.5psi boost. My IHI is much the same on my 998.
2nd Feb, 2011 at 09:10:19am
um,exactly. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
2nd Feb, 2011 at 09:45:42am
cummon robert, you know what I mean. My car make boost at 2.2k, but it dosen't really take of till nearer 3.
2nd Feb, 2011 at 11:50:31am
I see, so i wont feel any difference until 2,5k :) well that is actually ok to me, saves some gas.
2nd Feb, 2011 at 11:52:34am
On 2nd Feb, 2011 chominsh said:
hi mate! where exactly are you buying it from??? is it original - authorized seller?? I need one as well can not fined where to buy :( On 1st Feb, 2011 Utking said: Sorry, i meant 430£ :] Im not quite sure if it is a copy or not, will have to check it out further, the ones at the store didnt know either, but he said that there was a guy who bought one for his audi, a kk03 or something, and the turbo he had originnaly had all the same stamps as the new one, at the same places, only the mark on the turbo had been grinded away. So i still dont know
2nd Feb, 2011 at 12:04:18pm
Well I run T3 on a 1275, which is supprisingly ok. An IHI RHF4 on a 998 and a GT1752 on a 998.
2nd Feb, 2011 at 12:33:58pm
hmm sounds good, how much is the difference between the GT1752 and the IHI RHF4?
2nd Feb, 2011 at 12:53:57pm
Yes you will get boost earlier with the IHI. I would say the IHI is an easier fit as it's smaller. I had a manifold made then made my own elbow.
2nd Feb, 2011 at 01:09:20pm
wow, that sounds awesome, thanks a lot for the information |
2nd Feb, 2011 at 01:27:44pm
St3 head means nothing really. You need a head suitable for turbo use. Speak to BENROSS or Turbo Phill on this forum for guidance.
2nd Feb, 2011 at 06:52:31pm
Hmm thanks for the heads up, i will certainly do it |
![]() 31 Posts Member #: 1961 Member Wellington New Zealand |
3rd Feb, 2011 at 09:58:03am
The spec on the ihi is that it will flow enough air to produce hp from 62 to 177hp . I'm currently looking at fitting an older ihi VJ14. Yet to be comfirmed , but it looks like I'll be able to fit the engine without needing to cut the firewall to fit a turbo box section. (Custom manifold and exhuast down pipe required) The engine will however need to tilt forward a few degrees. The nice thing about this turbo over a t3 is that is spools up far quicker and will reach it's maxuim boost far sooner (very low turbo lag). Down side is that it will never produce the sort of power that is possible from the larger turbine turbos.
Edited by NealfromNZ on 3rd Feb, 2011. |
