Home > Help Needed / General Tech Chat > beam axle
pete
Member #: 275
bonie scotland
right then got all my bits to build beam axle. before i start welding stub pins onto beam does anybody think, if i make wheel track wider or narower, or just keep it standard track width
Doodmeister
Member #: 149
Alberta, Canada
Std unless you intend to move the shock mounting positions aswell.
mini6r4
Member #: 426
Maidstone, Kent
good luck mate, just finished installing mine, and it was an absolute nightmare from start to finish. looks superb now its on, although the shock mount is still slightly fouling on the radius arm. its a pretty tight fit in there, so adding half inch or so would definately help.
i think on mine i have about 2-3 mm between the shock and inner arch, and the same between the shock and the wheel, with an inch spacer ( i'm running deep dish 13x 7's)
www.mini-roadster.741.com
Roadster conversion kits on the way!
Doodmeister
Member #: 149
Alberta, Canada
Do you guys by chance have pictures and dimensions for the beam as i'm very interested in making my own setup.
pete
Member #: 275
bonie scotland
mine is live axle, rose jointed avo coil overs, i can not get pictures up on here, as i am FUCKING useless we computer plus i had a problem with it, i bought a mini 2 weeks ago it has a frame like what hudersfied mini spares sells with spax coil overs fitted no mods to body work ?50 any body wants it
Doodmeister
Member #: 149
Alberta, Canada
PM Sent
pete
Member #: 275
bonie scotland
ok karl, returned pm, are you going to york?
Doodmeister
Member #: 149
Alberta, Canada
I'm going on the monday i think but if that fall outside your plans i can go both days as i'm only 130 miles south.
pete
Member #: 275
bonie scotland
ok karl. were trying to get down on sunday
not sure you'll see as many minis on the sunday as traditionally its always been on the monday so i expect a lot of people to do monday only.
Doodmeister
Member #: 149
Alberta, Canada
Monday works better for me anyhow so monday it is..
Disk full (/tmp/#sql_c9d4b_0.MAI); waiting for someone to free some space... (errno: 28 "No space left on device")
