Home > Help Needed / General Tech Chat > Door hinges
rosco454
Member #: 5222
Northumberland
Quick question,how much play is acceptable on internal door hinges?
Im guessing none is the answer but dont know for sure.With them off the door I can wobble them about 1mm or so up and down in both the open and closed positions,with the door mounted to the car it has a bit of play that is most noticable when the door is near to closed.
My guess is that they are fucked and a new set is needed.Has anyone tried the lightweight ones from dsn as i dont want to pay over £100 for a genuine standard set which I will probably drill anyway?
Cheers Ross.
paneermeel
Member #: 1404
The Netherlands
No play should be there. Get some new ones:)
there is nothing wrong with a A-series that a turbo can't fix.
www.turbomini.nl
Ye must admit ross if theres play with them in your hand, imagine with the door on.
rick
rosco454
Member #: 5222
Northumberland
Bastards!
Thanks for the help lads,I already knew the answer really but was hopeful.Will have to dig deep and get some ordered up,lot of money for what they are though.
Cheers Ross.
