Home > Help Needed / General Tech Chat > triggerwheel m.e.d
clubbie70
Member #: 8935
netherlands
installed my MED triggerwheel and sensorbracket .
its an undermounterd bracket wich isn't 90 degrees from the keyway when engine is at tdc. In fact its more.
I know that, when Engine is on TDC i have to cut the tooth out at 90 degrees clockwise of the pickup.
But...........
The sensor is exactly at the downside of a tooth... how do i start counting to remove the correct tooth in the trigger wheel????
thanks
clubbie70
Member #: 8935
netherlands
it looks like this , shot through vr sensorhole
Alex1340
Member #: 111
Loughborough
is that bolt head right??? :-S
clubbie70
Member #: 8935
netherlands
It depends what the settings are in the ECU of choice. usually a VR sensor is set for 'rising edge' which is the approach of a tooth. 'falling edge' is the retreat of a tooth.
Looking at the picture, if the engine is indeed at true TDC, then the tooth is set at rising edge to the sensor.
In any case, we are only really talking about 5 degrees max variation, as long as you remove the correct tooth, 90 degrees away. any variation should be easily offset in the sttings of your chosen ECU, and it is always advised to check the actual sensor offset with a strobe light, before running the engine.
clubbie70
Member #: 8935
netherlands
i/m using the megajolt.
so if i understand correct i should start counting 9 teeth clockwise from the falling edge in the picture en remove nr 10 ?
