Home > Help Needed / General Tech Chat > Clutch return spring
wagon_rider
Member #: 9241
Edinburgh / Dumfries
Hi all,
Could somebody please confirm whether should I have a spring on my clutch slave cylinder?
I think it needs a damn good bleed but I'm not sure whether there should be a spring on there too!
Sorry for the slightly crap pic
Thanks for any help :)
turbominij
Member #: 2104
Essex - UK
no that is a verto cluch setup because of where the cylinder is mounted so return spring is needed
"Tuning should be a compromise between what is possible and what is necessary"
10)Thou shalt always quest for more power
wagon_rider
Member #: 9241
OK thanks for clearing that up.
Hoping a hardcore bleed will make it work a bit better :)
turbominij
Member #: 2104
Essex - UK
yes chances are you have air in the system and it can take forever to get rid of it.
Open the bleed nipple and leve it overnight. Clutches always seem to self bleed in my experience.
wagon_rider
Member #: 9241
Thanks for the advice
Its a slightly different set up from standard - It has a Landy reservoir and about 3m of pipe from front to back!
Guess that won't make too much of a difference.
I did put a reservoir's worth of fluid through already with a small improvement
haha. It's amazing what you don't see. Plainly the engine in the back of something.
What is it. My Nimbus has a standard sized master cylinder all piped through normal 'copper' brake pipes. feels normal. But I've never had to bleed it.
kenny2
Member #: 5362
wexford in ireland
its in a freestyle buggy
On 5th Jan, 2011 wolfie said:
wagon_rider
Member #: 9241
yes :)
Got its fired up at the weekend for the first time *evil*
The long pipe could help if you remove the slave and bleed it while it's held up high.
metroturbo
Member #: 989
North Yorkshire
Get an eezibleed and the job will be done in minutes.
What is really the difference between Verto and not. Why do the old version need a spring and the Verto not?
He did put 'return spring IS needed'
i think people read it too quickly *tongue*
turbominij
Member #: 2104
Essex - UK
Hahah classic what a miss type I ment not needed but atleast every one missed the obvious mistake. Was rushing to reply at work. That will teach me
"No return spring for verto setups"
