| Home > Technical Chat > Equal length manifolds | |||||||
![]() 966 Posts Member #: 358 Post Whore Snetterton, Norfolk |
12th Mar, 2005 at 11:00:59pm
Hi all, |
13th Mar, 2005 at 12:14:56am
Correct me if im wrong but i dont think pulse tuning is really a concern on a turbo motor..
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
13th Mar, 2005 at 04:32:31pm
There is no shockwave effect as the turbo doesn't have a pressure drop/surface to reflect from. But pipe sizing is important to maximise the pressure difference at the "pulse front" equal length and correctly sized tubes are the go here. A bit like an LCB. Problem with the mini is that you have to fit this lot in and a lot of surface area=lot of area for heat transfer. Underbonnet superheat anyone? You could lag it but I reckon the bends would possibly restrict the flow slightly and make the point self defeating. Janspeed did this (IIRC) and Jan was formerly a short stroke screamer man and knew all about his exhaust design, I expect. I reckon that the gains would be getting the turbo to spin up a tad better but the top end flow gain would not be realised unless you were expecting it to flow like a beast where you were using a massive boost, exhaust lift/duration, then the gain would only be small. Perhaps for class racing it might give you an edge, but since these guys can blow up virtually any engine with the welly of the standard set up, as they say "If it aint broke......."
Edited by Hedgemonkey on 13th Mar, 2005. Bugger off, I'm getting there. |
13th Mar, 2005 at 09:50:02pm
Its funny u should mention the mirage kit, cos i worked for mirage last year. I am just aiming to get the best flow i possibly can from the manifold. I have access to a flow bench and everything else i need at college, as well as a knowledgeable group of lecturers. However, you guys, like me love your minis and my lecturers are stumped!!!!
13th Mar, 2005 at 10:29:48pm
do some work slacker
14th Mar, 2005 at 02:15:24pm
Pulse tuning: Well crack on and let's get some REAL info on this.
Edited by turbodave16v on 14th Mar, 2005. On 17th Nov, 2014 Tom Fenton said:
450 Posts Member #: 449 Senior Member Oxford |
14th Mar, 2005 at 02:20:14pm
Yeah i would like to know that aswell
14th Mar, 2005 at 08:53:56pm
Shockwave tuning is really only any good on a car with an internal reflector (megaphone/reverse cone) or an open exhaust and a really long cam, hence why they have fallen out of favour in recent times due to fuel limitations/noise regulations.
15th Mar, 2005 at 12:13:53am
Well so far have just been playing about on CAD at the moment to try and get some ideas of the feasiblilty. Have been discussing it with my boss and the best idea he could come up with was turning the boost up to overcome the flow problem, but surely using the pulse tuning would make it all more efficient.
