| Home > Help Needed / General Tech Chat > Help needed to identify this LSD. | |||||||
196 Posts Member #: 2301 Advanced Member Blackpool , Lancashire |
5th Feb, 2011 at 02:02:27pm
I bought this a few years ago as a Salisbury LSD
http://s256.photobucket.com/albums/hh167/boz-reb-2303/
5th Feb, 2011 at 02:08:52pm
http://i609.photobucket.com/albums/tt176/boz-reb/new079.jpg http://s256.photobucket.com/albums/hh167/boz-reb-2303/
5th Feb, 2011 at 02:10:38pm
5th Feb, 2011 at 02:18:32pm
Im sure thats the one off ebay a few weeks ago?
Edited by paul wiginton on 5th Feb, 2011. I seriously doubt it! |
5th Feb, 2011 at 02:29:51pm
Thanks Paul, Ive had this one for 3 or 4 years and only just getting round to fitting it. http://s256.photobucket.com/albums/hh167/boz-reb-2303/
5th Feb, 2011 at 02:32:29pm
What is it set at? and seriously you wont like it in a daily driver I seriously doubt it! |
5th Feb, 2011 at 02:38:34pm
Not sure what you mean by set at ?
5th Feb, 2011 at 02:40:41pm
Id recommend a cross pin diff but if youre set on using the Salisbury you want it set about 55 - 60lbft (hardly worth it). You will need some of the inside of the case machined off so there is less pressure on the clutches I seriously doubt it! |
5th Feb, 2011 at 02:43:58pm
Count your teeth on the CWP again 56 and 14 makes 4, Im not so sure a 4.0:1 was ever made so you probably dont have a matched set of cogs I seriously doubt it! |
5th Feb, 2011 at 02:48:08pm
What would you do ? sell the Salisbury and get a cross pin then.
5th Feb, 2011 at 02:51:16pm
Its defiantly 56 on the crown wheel ive got that with me . Ill have to have a look at the pinion when I get home. http://s256.photobucket.com/albums/hh167/boz-reb-2303/
5th Feb, 2011 at 02:54:03pm
Sorry 55 teeth. Its stamped JKD 56. http://s256.photobucket.com/albums/hh167/boz-reb-2303/
5th Feb, 2011 at 02:55:52pm
My Salisbury was set at 80lb when I drove it a lot and it was seriously hard work to keep in a straight line. From experience you need all the front suspension rose jointed so there is no movement other than up and down and the tracking set parrallel, otherwise when one wheel loses traction, on a manhole cover or wet patch, the car will steer in the direction the other wheel is pointing. If you have rubber mounted suspension and tracking set as standard, that one wheel that still has traction will not be pointing straight forward and you will be in a hedge or on the other side of the road. If you try to correct it you will make it worse.
5th Feb, 2011 at 03:01:43pm
How , mutch do they sell for ? http://s256.photobucket.com/albums/hh167/boz-reb-2303/
5th Feb, 2011 at 03:08:00pm
Not sure tbh I seriously doubt it! |
7th Feb, 2011 at 10:46:09pm
Hi Paul, Ive had a look and the Crown Wheel is 55 and the pinion is 14.
8th Feb, 2011 at 06:37:10am
55/14 is a match, it makes 3.92:1 I seriously doubt it! |
