| Home > Help Needed / General Tech Chat > EDIS and megajolt problems | |||||||
![]() 257 Posts Member #: 7048 Senior Member Bridgend |
5th Feb, 2011 at 05:21:44pm
I've just installed the EDIS system on the mini, preparing it for the megajolt. It should run at a fixed 10 degrees advance with just the EDIS plugged in, I have spark, so popped the plugs in and it's just backfiring through the carb.
Turbo parts collector at the moment, almost ready. |
5th Feb, 2011 at 05:25:03pm
resistive plugs are woth a go, you are emnt to use them with ecu's but som people get away with normal ones,
5th Feb, 2011 at 05:28:12pm
Sounds like the timing is not at 10 deg to me. Are you 100% the sensor is 10 teeth anti-clockwise from the missing tooth? http://www.twin-turbo.co.uk
5th Feb, 2011 at 05:35:46pm
Just put some NGK R resistive plugs in and its still doing it.
5th Feb, 2011 at 05:53:00pm
5th Feb, 2011 at 05:59:18pm
yep that sounds wrong,
5th Feb, 2011 at 06:10:30pm
Yeah someone on TMF just gave me the answer, I've got to try adjust my sensor bracket to sir 90 degrees further forward on the wheel now. Cheers for the help, I know what need doing now atleast. Turbo parts collector at the moment, almost ready. |
5th Feb, 2011 at 06:13:46pm
could be easier to mod the wheel?
5th Feb, 2011 at 07:01:48pm
Thats a very good idea, I'll give that a go. Turbo parts collector at the moment, almost ready. |
5th Feb, 2011 at 07:44:38pm
Genius! that worked great, good idea, can I just confirm which tooth it has to read off at TDC, 90 degrees before, so 36 tooth wheel, that'd be tooth 9 before the missing tooth? My missing tooth is now sitting at TDC. Turbo parts collector at the moment, almost ready. |
5th Feb, 2011 at 08:01:41pm
yep, 9 teeth, 36 teeth for 360 deg 9 teeth for 90deg On 28th Aug, 2011 Kean said:
5th Feb, 2011 at 09:27:03pm
Thanks guys, it's running on EDIS now Turbo parts collector at the moment, almost ready. |
5th Feb, 2011 at 09:33:12pm
6th Feb, 2011 at 02:03:22pm
Ok got it all working great now, it's so much better than the dizzy. Just finishing up the installation, how do you attatch the hard rev limiter? It's soldered into the board unit just fine, but I don't know where it goes from the ECU. Turbo parts collector at the moment, almost ready. |
