| Home > Help Needed / General Tech Chat > diff | |||||||
107 Posts Member #: 9276 Advanced Member Darlington north east |
6th Feb, 2011 at 11:53:26am
6th Feb, 2011 at 12:02:26pm
Take it you mean the x pin if so then yes it will fit a or a+. But the minispares x pin is stronger as the pins are offset rather than at 90 degrees to each other. Hope this helps -MINI CLUBMAN 1380 TURBO- |
6th Feb, 2011 at 12:18:21pm
Don't need to buy anything else with. It then? |
6th Feb, 2011 at 02:59:48pm
maybe some shims so you can set it correctly in the housing, i think i needed an extra 8 thou, but that was probably because of the slightly thicker gaskets Yes i moved to the darkside |
