Home > Help Needed / General Tech Chat > Gearbox casings and ARP main studs..
jamie@thefatgarage
Member #: 9345
Sheffield
When I come to fit together my block and gearbox I found that the ARP main studs/nuts on both outer bearing caps foul the gearbox casing to the tune of about 4-5mm.
I presume some of you have encountered this before... is it just a case of grinding space for them or has someone got any helpful advice on the best ways to deal with this?
Do different gearbox cases have different designs in the affected areas? (mine is an early one...)
Cheers..
yep, grind/ file the gearbox case to suit,
A bit of tig welding is also required as you'll grind through
jamie@thefatgarage
Member #: 9345
Sheffield
Thanks chaps. I'll fire up the air drill and tig welder.
I just put my ARP main studs in the toolbox.....they're still sitting there 19 years later lol.
Will everyone have to do this then?
for the mains yes, not for the rods if your thinking that like i was*happy*
5portsrock
Member #: 2023
nr Portsmouth ,Hampshire
Some good info here .
http://www.aptfast.com/
follow the "How To " link then click on main studs .
jamie@thefatgarage
Member #: 9345
Sheffield
That is quite revealing. The nuts on the studs on that website are 12points, mine are 6 points and seem to be a bit longer. With the washers too makes them a lot longer.
I'm thinking of keeping the washers on the centre main to prevent the nuts eating into the cap over time and doing without washers on the front and rear ones, allowing me to shorten the studs in the lathe. As it stands I'll be removing a lot of material to get them to fit, way more than on the site link above. I might also visit the local fasteners place and see if they have any good tensile nuts that are shorter.
I'm guessing that they won't as I'm sure there must be some relationship between stud material, diameter, thread type and nut length.
5portsrock
Member #: 2023
Im pretty sure you can buy the multi piontnuts seperatley from an ARP dealer ( swiftune / Arrow components )
5portsrock
Member #: 2023
oops , made a mess of that , ment to say ,you can get the multi piont nuts seperatley from an ARP dealer ( swiftune / Arrow components ) etc
Mine had the 6 points, they were massive. They're in the toolbox along with the studs lol.
No way was I grinding the gearbox casing to make them fit. Std bolts do actually work just fine.
