| Home > Help Needed / General Tech Chat > turbo Hiff44 full repair service | |||||||
289 Posts Member #: 8160 Senior Member , mitcham, surrey, london, cr4 |
7th Feb, 2011 at 12:37:56am
hi there!
Edited by Nick on 8th Feb, 2011. Nothing special! |
7th Feb, 2011 at 12:43:49am
Just get the kit and do it at home mate thats what i did. The kit will tell you what to do. I have started posting on Instagram also my name on there is turbomk1golf
7th Feb, 2011 at 12:57:27am
its very easy, the hardest bit is cleaning the carb Yes i moved to the darkside |
7th Feb, 2011 at 07:56:45am
You can send it to Burlen, but it'll cost you a small fortune. As said it's easy enough to do yourself the kit comes with instructions.
7th Feb, 2011 at 08:26:31am
If only Burlen put the correct choke seals in. Anyone ever had the right ones? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
8th Feb, 2011 at 12:23:39am
On 7th Feb, 2011 wil_h said:
If only Burlen put the correct choke seals in. Anyone ever had the right ones? Nothing special! |
8th Feb, 2011 at 12:32:29am
On 7th Feb, 2011 Turbo Phil said:
You can send it to Burlen, but it'll cost you a small fortune. As said it's easy enough to do yourself the kit comes with instructions. There's a bit of a guide here: Nothing special! |
8th Feb, 2011 at 07:08:46am
Ill be rebuilding mine for the first time also, seems to be easy enough, just give it a go Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
8th Feb, 2011 at 08:14:44am
Have a look in the 'How To' section. Tom wrote it up, was very usefull when we rebuilt the van's carb. We just used brake cleaner in an aerosol can. On 11th Feb, 2015 robert said:
8th Feb, 2011 at 08:27:49am
^ Nah we weren't that pikey. We actually splashed out on some carb cleaner If something is worth doing, it's worth doing half of. |
8th Feb, 2011 at 10:52:37am
I find an overnight in a tin of thinners shifts most things.
8th Feb, 2011 at 11:11:18am
On 8th Feb, 2011 tadge44 said:
I find an overnight in a tin of thinners shifts most things. (on the carb. that is) Damn I was, err I mean a friend was wondering if it would help with the warts in his gentlemans regions!
8th Feb, 2011 at 11:27:54am
If only Burlen put the correct choke seals in. Anyone ever had the right ones? Nope, always resorted to generic O rings that fit. |
8th Feb, 2011 at 04:09:54pm
Oh, I see, you mean on the choke ?.
16th Feb, 2011 at 02:17:23pm
On 8th Feb, 2011 bennyy said:
Ill be rebuilding mine for the first time also, seems to be easy enough, just give it a go Nothing special! |
16th Feb, 2011 at 02:18:12pm
16th Feb, 2011 at 03:31:00pm
On 16th Feb, 2011 chominsh said:
hi mate, where did you bought repair kit for your hif44?? found one there http://www.turbo-mini.com/66091/63768.html but they do not reply on email and there is no option to order and pay by online :( searched in ebay and no luck as well :( On 8th Feb, 2011 bennyy said: Ill be rebuilding mine for the first time also, seems to be easy enough, just give it a go I'll check my email, it could have got caught in the junk filter by mistake. :) |
17th Feb, 2011 at 04:20:05pm
hi mate, where did you bought repair kit for your hif44?? found one there http://www.turbo-mini.com/66091/63768.html but they do not reply on email and there is no option to order and pay by online :( searched in ebay and no luck as well :( On 8th Feb, 2011 bennyy said: Ill be rebuilding mine for the first time also, seems to be easy enough, just give it a go I'll check my email, it could have got caught in the junk filter by mistake. :) Nothing special! |
![]() 1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
17th Feb, 2011 at 04:36:37pm
to clean the casing i actually left it overnight in a bucket of fresh petrol and gave it a scrub. spotless... On 17th Feb, 2011 apbellamy said:
I popped my first one out the other day... |
