| Home > Help Needed / General Tech Chat > wat happened?? | |||||||
![]() 514 Posts Member #: 5362 Post Whore wexford in ireland |
7th Feb, 2011 at 09:56:05am
so i got my car all together and running perfect last night, leant over to rev it on the carb got a shock off the dizzy and engine stalled! fuel keeps flowing out of the carb into the plenum and it wont start! any ideas??? On 5th Jan, 2011 wolfie said:
he floated over to mine for a bit of ring |
![]() 392 Posts Member #: 5702 Senior Member Cornwall |
7th Feb, 2011 at 10:01:41am
Have you checked if the plugs are sparking? |
7th Feb, 2011 at 10:10:31am
Your fuel pressure ir too high for one Fastest 998 mini in the world? 13.05 1/4 mile 106mph
7th Feb, 2011 at 10:11:25am
sorry meant to say checked plugs and even raplaced them, really good spark, On 5th Jan, 2011 wolfie said:
7th Feb, 2011 at 10:12:16am
7th Feb, 2011 at 10:18:59am
If you don't have a gauge. Take the dashpot off the carb and keep turnig the pressure down til fuel stops coming out of the jet.
7th Feb, 2011 at 10:25:52am
7th Feb, 2011 at 10:30:32am
would it still spark if that happened andy??
7th Feb, 2011 at 10:36:20am
Is it turbod? The Aldon yellow will be no use if it is. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
7th Feb, 2011 at 11:35:14am
yea its turbo, was running fine for last few days?? i've a dizzy from a 93 sprite any better? at least i tink ita a yellow! its defo an aldon tho On 5th Jan, 2011 wolfie said:
7th Feb, 2011 at 12:15:58pm
nope, you need a turbo dizzy or the advance curve will be miles out an you risk damaging your engine On 11th Feb, 2015 robert said:
7th Feb, 2011 at 12:33:31pm
7th Feb, 2011 at 12:36:31pm
On 7th Feb, 2011 kenny2 said:
ahhhhhhhhh fuck Not right now thanks am a bit busy.
However the above is correct, either get yourself a proper turbo dizzy, one of these 123-tune dizzies or even the tried and tested megajolt. It also sounds like you have a few other problems to sort. Get a fuel pressure gauge and get that set correct. If something is worth doing, it's worth doing half of. |
7th Feb, 2011 at 12:40:12pm
awh ![]() ![]() ![]()
i'll try source a turbo dizzy today, and set the pressure on the reg, damn awkward turbo better be worth it. On 5th Jan, 2011 wolfie said:
7th Feb, 2011 at 01:03:39pm
It will be, but you need to get the recipe right first. Once you go turbo, you won't On 11th Feb, 2015 robert said:
7th Feb, 2011 at 01:22:14pm
7th Feb, 2011 at 01:24:09pm
7th Feb, 2011 at 01:27:39pm
and i'm startin to build my house and garage this month so i'm defo broke for at least say 30yrs!!!! On 5th Jan, 2011 wolfie said:
![]() 1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
7th Feb, 2011 at 04:46:56pm
haha. itl be worth it tho On 17th Feb, 2011 apbellamy said:
I popped my first one out the other day... |
7th Feb, 2011 at 05:19:38pm
and a 1293 pick up in the garage!
![]() 232 Posts Member #: 1197 Senior Member Dublin Ireland |
8th Feb, 2011 at 05:16:04pm
No probs, anytime I can help mate,
8th Feb, 2011 at 05:36:05pm
