| Home > Help Needed / General Tech Chat > Metro brake problem | |||||||
84 Posts Member #: 2404 Advanced Member Braintree, Essex |
7th Feb, 2011 at 02:32:24pm
Actually Midas problem, but they're standard Metro brakes, with servo. Recently I had to change a rear wheel cylinder and couldn't bleed the brakes although I'ne never had trouble before. Tried a new m/c, no improvement. Took it to my local garage after which it was OK but since then the pedal has been getting lower and lower before the brakes bite. It doesn't pump up as you'd expect if there was air in the system, and there were no signs of a leak when it was MoT'd. I've got no idea what's going on, any suggestions please? Geoff |
7th Feb, 2011 at 02:44:08pm
Servo or master cylinder are shot I would expect.
7th Feb, 2011 at 03:20:30pm
Andy, the servo is only a couple of years old, but as it isn't part of the hydraulic system I can't see why it would make the pedal subside over a period of months. The old one was certainly shot, but it didn't cause these symptoms. The m/c is brand new, changed out of desperation really (with your reservoir!) but when I took the old one apart it looked in perfect order, as it should have done as it was only the same age as the servo. Geoff |
7th Feb, 2011 at 03:26:45pm
We had a similar problem with our van. Ended up with 2 pumps befoer it would stop. A new master cylinder cured it.
7th Feb, 2011 at 03:40:07pm
ballooning flexy hoses? If something is worth doing, it's worth doing half of. |
7th Feb, 2011 at 08:26:45pm
I've got the thing screwed into the m/c, called a pressure reducing valve in the manual. Presumably it just limits the maximum pressure? No idea how it works or if it can go wrong.
Geoff |
7th Feb, 2011 at 08:34:51pm
Im kindve having the same problem at the minute, except ive recently refurbed my braking system with stainless pistons and new seals, braided hoses.
8th Feb, 2011 at 07:42:57am
Even if the servo is new it could be at fault.
8th Feb, 2011 at 08:40:42am
If the servo has failed wouldn't it just mean the brakes get heavier? It's doing something because you can feel the pedal go down when the engine starts. Tickover is OK so I don't think there's an air leak Geoff |
