Home > For Sale > Vmax MPI Supercharger Kit full and complete -price dropped
Andy500
Member #: 2443
Cheshire
Hi Chaps,
A complete VMAXscart MPI Supercharger kit. Anyone who has followed my posts will know that this has undergone quite extensive research and Ive spent the best part of £1000 on the rollers at emerald perfecting it. It also produces 136bhp and 140lbft of torque with the maps to prove (from Emerald so not a tuners exagerated figure).
I would be looking to sell it as a complete kit but could seperate if needed, basically the following would be included:
>Eaton m45 5th generation charger, (covered less than 3K) with oversized pulley to drop boost to 10 PSI
>VMAX scart charge cooler
>Bespoke stainless inlet manifold complete with IAT sensor and MAP sensor take off. (map sensor also supplied)
>Bespoke custom made 316 2"stainless supercharger inlet pipe with IACV take of so its across the throttle body and works correctly!
>Burlen 52mm Throttle body
>Rover MPI IACV
>2xMPI injectors
>Rob Walker Stage 3 head, rebuilt approx 1000 miles ago with new valves and springs by Morspeed
>Modified Water pump (I run a standard MPI rad and expansion tank and do not have problems with overheating)
>Bespoke alloy water pump pulley
>Emerald M3D ECU with Wideband Lambda (Innovate LC1) With full maps by Dave walker for 1293cc and 1275 using this head and set up)
> New Devils Own Water Injection Kit (Never fitted but would have been my next step and would allow higher boost levels)
>FSE Fuel pressure regulator
>Inline fuel pressure gauge
In short this must be one of the best suck through M45 setups out there, it is reliable and now performs very very well. What would be provided is pretty much everything you need to bolt on to an MPI. Vmax still supply a Kit which is the MPI kit plus the plus pack at a cost of £4k. Which doesnt include all the parts in this kit or Dave Walkers expertise!
Everything has covered less than 4000 miles (i reckon 3000 of them were on the damn rollers!!!! LOL)
All fits under a standard round nose bonnet.
So what do you think would be the intrest in this, I need to sell it all or it stays as it is for now! Happy to recieve any sensible offers and can be seen in the car running.
Quick sale wanted so looking for something in the region of £2250.
Thanks
Andy
Edited by Andy500 on 13th Jul, 2011.
welshdan
Member #: 1111
s wales
any sort of guide of what you would be looking at for this? thanks
Andy500
Member #: 2443
Cheshire
Hi Dan,
Not 100% sure its cost me well in excess of £6K to date but obviously i know that its not worth as much second hand.
Considering the Kit would cost 4k from Vmax and to sort it properly you would still need to make a new water pump pulley, buy the cam, rockers, rocker cover, and IACV and then manufacture a new inlet pipe, have a bigger charger pulley made, modify the inlet manifold for map and IAT sensors buy a map sensor, and spend a few hundred quid at Emerald getting it properly mapped, then theres the water injection kit which costs £350.
Hence was thinking in the region of £3k
Andy
Andy500
Member #: 2443
Cheshire
Hi all ive now edited the above and dropped the price to £2250. Would make a great kit for someone wanting to bolt this on to an MPI! The same kit from Vmaxscart without all the improved and additional parts now costs a couple of pound under £4k!
Thanks
Andy
