Home > Help Needed / General Tech Chat > Omega forged pistons
andyuk1275
Member #: 9276
Darlington north east
Hi all.
im running a std A+ 1275
Can someone point me in the right direction of pistons....
The bloke whos going to help me put the turbo in and rebuilt the motor said i need 10cc dished forged but omega dont do them, is there a better option?
whats the advantage or having high and low cc's when it comes to pistons?
thanks
turbominij
Member #: 2104
Essex - UK
the 10cc omega pistons are cast and are what most people on here use.
im going to be runnig 18psi on these. and hopefully over 180bhp once i have finished my upgrades. my cr is 8.0:1
if you want forged they are 18cc and are only generaly needed for very hi power
the higher cc dish will allow you to run more boost. as it will lower the compression ratio(cr).
"Tuning should be a compromise between what is possible and what is necessary"
10)Thou shalt always quest for more power
The advantage of having the CCs in the head is that the piston will run cooler. The advantage of having the CCs in the piston is better breathing ( On the A-series) You choose.
Andy please take this the right way, but you need to do some reading up. Lowering the compression ratio for a turbo engine is a pretty fundamental concept that you need to understand really.
bennyy
Member #: 9037
Doncaster, yorkshire
The 10cc cast omegas are the pistons to use IMO, plenty of people use and reccomend them, these are the ones ill be using on my new build
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
bennyy
Member #: 9037
The 10cc cast omegas are the pistons to use IMO, plenty of people use and recommend them, these are the ones ill be using on my new build
andy the cast omegas are well proven!
and at a good price, you will be better off getting +20"s and 10cc dish in the top and having having the block bored
you will then have a 1293 cc engine,
and ..... as tom says
hope this helps
