| Home > Help Needed / General Tech Chat > removable front | |||||||
347 Posts Member #: 9075 Senior Member Peterborough |
9th Feb, 2011 at 10:32:25pm
Oh wise people of Turbo Minis, I thought I'd ask your thoughts and opinions, hints and tips and general advisories on removable/flip fronts.
9th Feb, 2011 at 11:44:49pm
my advise, and my opinion,
Yes i moved to the darkside |
10th Feb, 2011 at 09:40:10am
Yeah it will definitely be two piece with a plastic bonnet... why people want to remove the whole front just to top up their oil I don't know... haha.
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
10th Feb, 2011 at 10:03:58am
Ive seen removable fronts done without splitting the front arches. Using group5/7 arches with captive nuts in the a panels. Then just un bolt the 2 nuts on each a panel to remove. Or if you split them then bond a lip onto the underside of the part attached to the a panel to support the arch when in position. one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
10th Feb, 2011 at 10:43:54am
That was exactly my plan.
On 10th Feb, 2011 wez said:
Ive seen removable fronts done without splitting the front arches. Using group5/7 arches with captive nuts in the a panels. Then just un bolt the 2 nuts on each a panel to remove. |
10th Feb, 2011 at 11:41:04am
I have a removable steel front for sale if your interested? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
10th Feb, 2011 at 12:36:09pm
On 9th Feb, 2011 DaveVader said:
don't really want a flip front as the flip forward idea just doesn't work for me and the flip up is awesome but expensive (or so I've heard) and American. I've gone for flip upwards. The only commercially produced hinges are indeed American and expensive. So I decided to improvise - after a couple of unsuccessful trials with cantilever window hinges (which are clever but won't go beyond 90 degrees) I read somewhere that certain model Audi boot hinges work the same way as the American Mini flip front ones. Andy (apbellamy on here) has the right Audi so took a couple of photos for me of the inside of his boot and I just copied the basic design and made my own out of rectangular steel bar. Schrödinger's cat - so which one am I ??? |
10th Feb, 2011 at 01:04:35pm
That's pretty cool, you got any pictures?
10th Feb, 2011 at 01:37:56pm
I haven't got any close-up of the hinges but one to show how far it goes (there are more in my build thread)
10th Feb, 2011 at 01:51:23pm
That looks pretty impressive.
11th Feb, 2011 at 09:08:31am
I've been thinking about brace bars aswell and instead of just bars have them as part of the cage.
11th Feb, 2011 at 12:27:32pm
Dave,
11th Feb, 2011 at 12:49:53pm
I sort of had that in the back of my mind. In my head I thought that without a cross bar at the front the cage will just end and there will be possible side to side movement.
11th Feb, 2011 at 01:08:58pm
It's not so much preventing movement side to side compared to single bars (although it does that as well), it's more about preventing the front rail of the subframe twisting allowing the tie bar mounting position to move under suspension loads.
12th Feb, 2011 at 10:43:56pm
Well it looks like I am definitely going for a removable front... I just chopped my innter wings off :)
