| Home > General Chat > Split Radius Arm Grease Tubes | |||||||
13th Feb, 2011 at 09:05:22pm
Are no more for me On 26th Oct, 2004 TurboDave16v said:
![]() 509 Posts Member #: 1027 Post Whore Germini, black forrest |
13th Feb, 2011 at 10:17:40pm
Sprocket, we did a radius arm repair session last year. So we had quite few sets of repair kits. Some tubes were allready split from new!! We threw them away and fitted the metal tubes someone over here remanufactures (not hard to do realy).
Edited by Asphalt on 13th Feb, 2011. [X] nail here for new monitor |
14th Feb, 2011 at 04:16:17am
always wondered why i lost a tub of grease into my radious arms come mot time :( Yes i moved to the darkside |
14th Feb, 2011 at 09:28:24am
I remember a while ago heating a radius arm up to let the grease run out. I was surprised at the time how much it can hold! |
14th Feb, 2011 at 06:27:17pm
shit the bed that is a lot of grease. I have started posting on Instagram also my name on there is turbomk1golf
![]() 428 Posts Member #: 39 Senior Member Bristol |
14th Feb, 2011 at 07:58:59pm
thats one poor design...so to much pressure and the tube breaks and you fill your radius arms..! |
14th Feb, 2011 at 09:32:37pm
On 14th Feb, 2011 Monster22 said:
thats one poor design...so to much pressure and the tube breaks and you fill your radius arms..! Exactely. The older Minis were fitted with nuclear bomb proof metal tubes. Later ones got - probably to save some pennys - plastic tubes. Tho original tubes are a lot better quality than those you get in today's repair kits... The NOS ones from the picture is postet are very solid and flexible - the newer ones are fragileand brittle... And some are even split before the have been fitted... So basicaly - try to get you hands on the metal tubes... Only one downside: they are about 100 grammes heavyer (noin this rare case it's not good to drill additional holes )
We found it best to use and old shaft as a guide when fitting/knocking in the metal tubes. [X] nail here for new monitor |
14th Feb, 2011 at 09:49:02pm
Force racing new product? Ti grease tubes? If something is worth doing, it's worth doing half of. |
14th Feb, 2011 at 10:01:05pm
That looks mucky as fuck! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
14th Feb, 2011 at 10:25:56pm
Its a bit time team how old do you think it gos to I have started posting on Instagram also my name on there is turbomk1golf
14th Feb, 2011 at 11:14:09pm
On 14th Feb, 2011 madmk1 said:
Its a bit time team how old do you think it gos to To quote from Sumerford Minis catalog "Towards the end of the 1980s the rubber cone suspension radius arms were modified to incorporate a stub axle seal. Also, the steel lubricating tube for the radius arm pivot shaft was replaced with a nylon item." So if it has an O ring at the base of the stub axle beind the rear most hub bearing, it has plastic tubes from the factory. If on the other hand you have an earlier radius arm without the o ring, and its never had the pivot shaft and bearings replaced, its a good bet that they might be the metal tubes. If some one has messed with it, then its any mans guess as to wht might be fitted, but I would put my money on them being plastic, as that is all you can get these days, which is why I paid a little extra on Ebay for the NOS Quinten Hazel kit with the metl tubes
![]() 1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
15th Feb, 2011 at 12:24:36am
My refurbed ones from minisport where split from when they where on, at the time I didn't think anything of it when they took more than the usuall amount of grease, and by the time I found out about this problem it was too late to send them back. On 17th Feb, 2011 apbellamy said:
I popped my first one out the other day... |
15th Feb, 2011 at 10:56:59am
At what temp does grease become liquified?? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
15th Feb, 2011 at 11:17:39am
15th Feb, 2011 at 11:34:44am
Are we talking mega heat or 200deg Gas Mark 5 lol?? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
15th Feb, 2011 at 11:45:58am
Aoven would be better as you can get the whole thing up to temperature, 200 degrees would probibly do it, but I wouldnt advise doing this in the kitchen oven! Just heat the radius arm with a gas burner evenly to soften up the grease incontact with it, then give it some sharp dunts on a block of wood, and fish out the large part of the grease by passing the spindle through its hole a few times. Repeat until you are satisfied.
15th Feb, 2011 at 11:52:42am
Suck it out mike If something is worth doing, it's worth doing half of. |
15th Feb, 2011 at 11:56:04am
How much would it compromise the strength of the arm if you drilled a hole near the stub axle to blow the grease out with an airline? |
15th Feb, 2011 at 12:09:08pm
My sucking skills arent as polished as yours.
On 15th Feb, 2011 John said:
Suck it out mike ![]() 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
15th Feb, 2011 at 12:21:26pm
Get some practice then. If something is worth doing, it's worth doing half of. |
31 Posts Member #: 9334 Member |
18th Feb, 2011 at 02:36:23pm
You could probably work something out with a bit of plaggy pipe and an airline/pressure washer.
18th Feb, 2011 at 06:38:41pm
Good post there, i didn't know that. Best 1/4 mile 13.2 seconds @116 mph
21st Feb, 2011 at 12:06:23pm
On 13th Feb, 2011 Asphalt said:
And most interesting...
Cheers, Jan lol, no wonder were running out of fossil fuels "Turbo's make torque, and torque makes fun"
