Home > Wanted > i am in need of one of these relays for a mates car
turbominij
Member #: 2104
Essex - UK
has anyone got one?
http://www.minispares.com/Product.aspx?ty=...id=33908&title=
Edited by turbominij on 15th Feb, 2011.
"Tuning should be a compromise between what is possible and what is necessary"
10)Thou shalt always quest for more power
I'm pretty sure if you take it down to your local factors, they will be able to match it to something
try somerfords
turbominij
Member #: 2104
Essex - UK
My mate works for a motor factor and can't get one it's him looking for the part. Hadn't thought of sumerfords
not as easy as I thought - just come up with this using the minispares part number
http://cgi.ebay.co.uk/Starter-Relay-some-M...=item3f06a43661
Just use a bog stanard starter relay and jiggle the wires about so that it pairs up if its a different configuration
adcyork
Member #: 6807
York
seconded
or just buy the right one only £9-15 and no jigging needed
turbominij
Member #: 2104
Essex - UK
wolfie i agree with you if a jobs worth doing its worth doing properly
