| Home > Help Needed / General Tech Chat > Removing a rear roll cage | |||||||
![]() 558 Posts Member #: 8143 Post Whore London |
16th Feb, 2011 at 06:36:53pm
Edited by dischub on 16th Feb, 2011. |
16th Feb, 2011 at 08:45:38pm
rachet straps r the way forward. |
![]() 460 Posts Member #: 843 Senior Member Stoke-on-Trent. Duck. |
16th Feb, 2011 at 08:56:05pm
Ratchet straps on the legs to the rear arches, it's getting past the B pillars that's tricky. Tip it forward and it should come out - doors aren't the problem, I usually end up taking off the steering wheel as that seems to be the obstructive bugger!
![]() 611 Posts Member #: 5222 Post Whore Northumberland |
16th Feb, 2011 at 09:44:04pm
The rear legs catch the b pillars as the shell narrows towards the roof,be careful not to catch the door bins/b pillars with the cage feet as they like to chew the paint off the body.
I have a bit of a fetish for tools |
16th Feb, 2011 at 09:58:03pm
Thanks guys, I'll give it a go! |
17th Feb, 2011 at 07:35:24am
If all else fails, hit it with the biggest hammer you can find On 11th Feb, 2015 robert said:
![]() 514 Posts Member #: 2104 Post Whore Essex - UK |
17th Feb, 2011 at 09:12:13am
i ended up taking the sinscreen out of mine to get it in last weekend. made life easier and i wanted to replace the rubber anyways so though might as well do both at the same time.
"Tuning should be a compromise between what is possible and what is necessary"
