| Home > Help Needed / General Tech Chat > Need help with brakes in west mids. | |||||||
17th Feb, 2011 at 07:21:44pm
Im at wits end with my front brakes, after a year and a half of forever fighting with them i bought a new set of calipers to go down onto 7.5" discs.
17th Feb, 2011 at 09:01:10pm
wot exactly is happening were is it leaking |
17th Feb, 2011 at 09:05:01pm
Keeps leaking from where the braided hose screws into the caliper, ive tried copper washers and it still leaks when you try to use the brakes, i was most of the way through trying ptfe tape earlier when i just hit a wall and gave up.
17th Feb, 2011 at 10:15:51pm
you could try some new brake lines from the subframe to the caliper - are the threads on the banjo ok? |
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
18th Feb, 2011 at 03:53:24pm
Could there be something up with the master cylinder, possibly sending too much pressure to one side??? Does it leak from one side or both? If only one side, is it the same side the brakes used to pull to before??? one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
18th Feb, 2011 at 05:33:32pm
Leaks both sides, banjo is fine for a change, i have new braided lines, one is 6 months old on the front, might change to the brand new one i just bought, and one is brand new, as i couldnt get it off the old caliper.
18th Feb, 2011 at 05:49:10pm
From your last post - are you saying that there is not a flat machined surface for the copper washer to seal on ?
18th Feb, 2011 at 05:55:36pm
Nah its just flat with minor suface imperfections from casting, tempted to take the calipers off and grind them flat or just bollock the thread on the hose with PTFE
18th Feb, 2011 at 06:05:48pm
I wouldn't grind the callipers mate.. Send them back if they are not perfect. I would pop over and help but I'm mega busy at the moment. Edited by MarkGTT on 18th Feb, 2011. |
18th Feb, 2011 at 06:18:50pm
If i send them back, likelyhood is i'll be left without a car for weeks.
18th Feb, 2011 at 06:20:36pm
As the saying goes, a picture says a thousand words.
18th Feb, 2011 at 06:27:33pm
Brb then, ill get my whiffy turd of a phone camera on the situation.
18th Feb, 2011 at 06:58:52pm
Something doesnt look right in that first pic. It looks like there is either two copper washers fitted or the copper washer is loose and not compressed between the hose fitting and caliper.
![]() 539 Posts Member #: 6807 Post Whore York |
18th Feb, 2011 at 07:04:11pm
Is the hole in the copper washer a close fit over the thread or are they able to float about?
Edited by adcyork on 18th Feb, 2011. |
18th Feb, 2011 at 07:11:24pm
The first picture, is probably from me having to tighten it up that much its bowed the copper washer up.
18th Feb, 2011 at 08:27:36pm
As above, the copper washer looks too big for those hoses.
18th Feb, 2011 at 08:36:30pm
Aiight mate, ill get my mate to take me anyway, i need another bottle of brake fluid aswell as the washers, ive gotten through a gallon tub this year so far due to problems. :/ On 26th Jan, 2012 Tom Fenton said:
18th Feb, 2011 at 08:55:09pm
hope your not paying top wack from halfords |
18th Feb, 2011 at 08:55:39pm
19th Feb, 2011 at 07:23:33am
also measure the depth of the thread hole and measure the screw i part of the brake pipe. technical names are beyond me this morning |
337 Posts Member #: 9138 Senior Member wolves |
19th Feb, 2011 at 10:28:25am
i can pop over sunday if its any use to ya ? |
21st Feb, 2011 at 07:59:17pm
Sort of sorted now, i have a very small leak passener side i CANNOT get rid of, so im taking the car to somebody now its drivable, this is why it was shocking before, the washer i got with the hoses just wasnt anywhere near the size it should be.
21st Feb, 2011 at 08:13:49pm
Glad you have sorted it. |
