| Home > Help Needed / General Tech Chat > 1275 metro turbo mini conversion | |||||||
6 Posts Member #: 9374 Junior Member birmingham |
19th Feb, 2011 at 07:58:39pm
i have bought a mini which has been converted to a 1275 metro turbo engine with a t3 turbo. the engine has been rebuilt with various mods.
![]() 871 Posts Member #: 2590 Post Whore Croydon |
19th Feb, 2011 at 09:00:31pm
sounds like the engine i sold, and the guy who bought it couldnt work it out either!
19th Feb, 2011 at 09:03:40pm
have you checked the compression ratio and fueling? is the choke sticking and making it run really rich? what does it souund like on idle and what do you mean by doesnt do much? as in doesnt make boost or what? reving the engine without any load wont spool the turbo up properly Drives
150 Posts Member #: 8909 Advanced Member North Cornwall |
20th Feb, 2011 at 09:47:53am
Almost sounds abit fuel like if it won't rev. If in doubt... flat out! The words of a true legend |
20th Feb, 2011 at 01:44:22pm
yer thats what i thought but its got a brand new turbo marine fuel hose with the red top facet fuel pump which is working correctly. when you put your foot on the accelerator it doesnt rev for a good 4-5 seconds then will pik up revs even if your foot aint on the pedal then when it drops revs going back down to tick over it cuts the engine out?
20th Feb, 2011 at 01:54:34pm
The red top fuel pump is your problem. It's not suitable for boosted applications.
In the 13's at last!.. Just |
20th Feb, 2011 at 02:07:41pm
Cavalier gsi pump or metro turbo i belive there pritty much the same and a decent fuel pressure reg, iirc the facet red pumps are no good as they only give 6or 7psi max pressure where as the metty one is 15 i belive so it starves the engine of fuel. Drives
20th Feb, 2011 at 02:22:26pm
we've got one of these on the van
20th Feb, 2011 at 03:07:15pm
ok thanks for the help |
20th Feb, 2011 at 05:00:20pm
You need a pump which can supply a higher pressure than the boost you plan to run. In which case the standard Metro Turbo pump is fine for most folks as it supplies about 36psi.
