| Home > General Chat > How to work out what spark plugs to use. | |||||||
![]() 902 Posts Member #: 111 Post Whore Loughborough |
19th Feb, 2011 at 08:05:15pm
I've comming up to getting my mini back on the road in march and i've got a rolling road planned for april. In preperation for the session i need to give it a service and make sure i have the right plugs.
19th Feb, 2011 at 08:46:06pm
C/R is probably going to have the largest effect on it, but I would use a 6 and go from there depending how the rr goes.
19th Feb, 2011 at 08:48:02pm
going by NGK heat ranges...
19th Feb, 2011 at 09:38:36pm
Spot on with Steve. I used ngk 7s in my 1380 N/a and it was spot on. Best 1/4 mile 13.2 seconds @116 mph
388 Posts Member #: 442 Senior Member Manchester |
20th Feb, 2011 at 10:53:23am
What sort of ignition system are you using? Depending on which will mean using resistive plugs or not. Edited by mcalvert39 on 20th Feb, 2011. |
20th Feb, 2011 at 12:14:37pm
There is no reason to use a non-resistive plug.
250 Posts Member #: 1615 Senior Member Ferndown, Dorset |
20th Feb, 2011 at 02:59:40pm
ive got 6's in a near identical spec engine On 1st Mar, 2009 MikeRace said:
Hmmm weberyyy On 21st Apr, 2009 madcatminis said:
I hope she's got knickers on or you'll have a funny runny mark on your bonnet. Quite like what a snail leaves behind. |
20th Feb, 2011 at 10:08:02pm
Im using Megajolts with the ford coilpack.
20th Feb, 2011 at 10:29:24pm
BPR6ES should do the trick |
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
20th Feb, 2011 at 11:27:52pm
On 20th Feb, 2011 Kean said:
BPR6ES should do the trick I agree with Kean. Good all-round plug, fine for your NA 1380 and if turbo go to BCR7ES. Richard. Minivanless, but reluctantly happy living with the decision. There'll be another one day.
