| Home > General Chat > Filler? | |||||||
![]() 611 Posts Member #: 5222 Post Whore Northumberland |
20th Feb, 2011 at 05:51:24pm
Edited by rosco454 on 20th Feb, 2011. On 20th Jan, 2011 apbellamy said:
I have a bit of a fetish for tools |
20th Feb, 2011 at 06:21:14pm
I use U-pol stuff from the local paint supplier - not sure exactly which one but I know i've got a separate stopper |
![]() 497 Posts Member #: 7641 Senior Member Jersey, CI |
20th Feb, 2011 at 07:03:19pm
I've used U-pol in the past and had no problems - at the moment i tend to stick to using "Ultra Smart 2k", which is made by Tetrosyl. For a stopper i use a Max meyer single pack stopper - i've never really heard of a combined product to be honest - always thought a body filler should be a 2 pack product that you mix to suit - and the stopper was a single pack.....
![]() 1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
20th Feb, 2011 at 07:09:32pm
Use upol easysand at work and on little bitts on the car. Great finish with it and it's a good consistency to apply easily when fresh. On 17th Feb, 2011 apbellamy said:
I popped my first one out the other day... |
20th Feb, 2011 at 07:17:10pm
I think I worded my first post badly,the fantasic stuff you mix with a hardener but its fine enough not to need a stopper afterwards apparently.
458 Posts Member #: 1840 Senior Member Kings Lynn, Norfolk |
20th Feb, 2011 at 09:09:03pm
I use Upol fantastic and it does what it says on the tin. No issues with it at all. |
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
20th Feb, 2011 at 11:33:54pm
Upol Easysand any day.
21st Feb, 2011 at 09:10:54am
Thanks for the advice guys.
296 Posts Member #: 7876 Senior Member Walsall West Midlands WS1 2DW |
21st Feb, 2011 at 12:29:45pm
Sorry for my ignorance but just reading this post and wondered what a 'stopper' is or used for? thanks Steve Patina=old and knackered and won't clean up |
21st Feb, 2011 at 12:46:41pm
On 21st Feb, 2011 Steve A said:
Sorry for my ignorance but just reading this post and wondered what a 'stopper' is or used for? thanks Steve Stopper is used to fill pinholes, light scratches or any other similar imperfections, just before painting. Fibreglass/filler is notorious for leaving pinholes which are not the most noticeable - once you've cleaned and sprayed a layer of primer, you're usually left with a few dents/pinholes/scratches that you didn't notice before - Stopper is a single pack fine filler (No mixing), drys in a couple of mins and quickly and easily fills these before & after primer.... |
21st Feb, 2011 at 06:15:48pm
Ross, you wont go wrong with the fantastic.
