| Home > Help Needed / General Tech Chat > Gear selector wont spin out the way? | |||||||
![]() 174 Posts Member #: 9041 Advanced Member Essex |
21st Feb, 2011 at 05:15:32pm
Hi guys Changing my box over and need to undo the pinion nut to put on my new box.
21st Feb, 2011 at 05:22:48pm
Make sure reverse gear isnt meshed I seriously doubt it! |
21st Feb, 2011 at 05:28:14pm
Have you taken the spring, ball and sleeve out of the side of the diff cover? They locate the selector shaft. On 11th Feb, 2015 robert said:
21st Feb, 2011 at 05:40:47pm
The reverse gear is lined up lovely just dont wanna turn.
21st Feb, 2011 at 05:46:44pm
If all 3 selector forks are lined up it should just rotate out the way, try a little exra force (not too much) by putting a screwdriver through the rollpin hole and turning it I seriously doubt it! |
21st Feb, 2011 at 05:48:03pm
Looking at the rear of the box (diff end), when you take the right hand output shaft/pot joint cover of and look for a hole in line with the selector rod. In that hole is a spring, a sleeve and a ball bearing. The ball locates in a groove on the selector shaft. You need them out so that the shaft can move in and out.
21st Feb, 2011 at 05:50:16pm
just done mine this morn. i just got it in neutral the turned it as far anti clockwise as it would. which made it come out 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
21st Feb, 2011 at 06:08:15pm
Yer its a rod change box.
21st Feb, 2011 at 06:10:16pm
sometimes they pop out and sometimes they need a little persuasion. On 11th Feb, 2015 robert said:
21st Feb, 2011 at 06:35:15pm
yes as andy says, check that the metal sleave and detent ball and sping have been removed. On 26th Oct, 2004 TurboDave16v said:
21st Feb, 2011 at 06:38:41pm
Ah yes, the metal sleeve - that'll do it I seriously doubt it! |
21st Feb, 2011 at 10:41:01pm
its the metal sleeve that stops it from going over, had me amused for a few hours when i rebuilt mine Yes i moved to the darkside |
25th Feb, 2011 at 08:06:15pm
Finally got out in the garage for a wile tonight yes it was the metal sleeve but there was no spring and ball...? |
26th Feb, 2011 at 08:40:20am
you'll need a spring and ball or you won't be able to get gears. The selector rod will just do as it feels... On 11th Feb, 2015 robert said:
26th Feb, 2011 at 09:39:50am
And when you find the spring and ball that go inside the sleeve there is a fourth very important part to putting it back together.....
