Home > Help Needed / General Tech Chat > What fuel to use.
Aussie_Dan
Member #: 461
Queensland Australia
Just a quick question to find out what the result of running premium unleaded in an A+ motor with a turbo head. Is Av gas a better option?
turbo hogster
Member #: 178
stowmaket suffolk
yes but you will need some pliers to pull you plugs out from bonnet, lol.
i would say 95 ron is ok 97 ron is better, but if you go over 100 ron the supurb,
avgas is about 120 ron i think but i would back of the dizzy a few deg if you try it,
butter done on the rollers with water down avgas eg 50-50 to pump gas, then try it.
or even 25-75 ratio firswt i wouldnt go to mad.
better still run lox (liquid oxygen) you wouldnt need spark plugs at all then, but get a good push bike and a metal detector so you can find your engine bits lol.
aussie dan,
Basically, high fuel octane, which suits your particular engine configuration
Consistent with your engines ability to stay out of detonation.
So say your running 95 Ron and running boost to 7psi only and your engines not detonating then there?s no point in going to a higher octane if this is costing you more out of the back pocket.
But if you up the boost and detonation try?s to set in going up a couple of Ron would cure the problem.
Below is a document of which I found and posted a few months ago
Should give you a reasonable explanation of what?s what.*happy*
Its all to do with compression ratio, boost pressure and keeping out of the dark side of the detonation.
if you understand this then it all falls in to place!
Hope this helps:*smiley*
FUEL OCTANE VS HORSEPOWER
IN TURBOCHARGED ENGINES THERE IS A FINE BALANCING ACT WHEN IT COMES TO MAKING A LOT OF POWER ON LOW OCTANE FUEL. IN MOST CASES, IGNITION TIMING MUST BE RETARDED AS THE BOOST PRESSURE RISES ABOVE A CRITICAL POINT AND FINALLY THERE REACHES A FURTHER POINT WHERE THE ENGINE SIMPLY LOSES POWER. IF THE TIMING WAS NOT RETARDED WITH INCREASING BOOST, DESTRUCTIVE PREIGNITION OR DETONATION WOULD OCCUR. NORMAL COMBUSTION IS CHARACTERIZED BY SMOOTH, EVEN BURNING OF THE FUEL/AIR MIXTURE. DETONATION IS CHARACTERIZED BY RAPID, UNCONTROLLED TEMPERATURE AND PRESSURE RISES MORE CLOSELY AKIN TO AN EXPLOSION. IT'S EFFECTS ARE SIMILAR TO TAKING A HAMMER TO THE TOP OF YOUR PISTONS.
MOST ENGINES MAKE MAXIMUM POWER WHEN PEAK CYLINDER PRESSURES ARE OBTAINED WITH THE CRANKSHAFT AROUND 15 DEGREES AFTER TDC. EXPERIMENTATION WITH INCREASING BOOST AND DECREASING TIMING BASICALLY ALTERS WHERE AND HOW MUCH FORCE IS PRODUCED ON THE CRANKSHAFT. SEVERELY RETARDED TIMING CAUSES HIGH EXHAUST GAS TEMPERATURES, WHICH CAN LEAD TO PREIGNITION AND EXHAUST VALVE AND TURBO DAMAGE.
WE HAVE A HYPOTHETICAL ENGINE. IT'S A 2.0L, 4 VALVE PER CYLINDER, 4 CYLINDER TYPE WITH A 9.0 TO 1 COMPRESSION RATIO AND IT'S TURBOCHARGED. ON THE DYNO, THE MOTOR PUTS OUT 200HP AT 4PSI BOOST WITH THE TIMING AT THE STOCK SETTING OF 35 DEGREES ON 92 OCTANE PUMP GAS WITH AN AIR/FUEL RATIO OF 14 TO 1. WE RETARD THE TIMING TO 30 DEGREES AND CAN NOW RUN 7PSI AND MAKE 225HP BEFORE DETONATION OCCURS. NOW WE RICHEN THE MIXTURE TO 12 TO 1 AFR AND FIND WE CAN GET 8PSI AND 235 HP BEFORE DETONATION OCCURS. THE LAST THING WE CAN CONSIDER IS TO LOWER THE COMPRESSION RATIO TO 7 TO1. BACK ON THE DYNO, WE CAN NOW RUN 10PSI WITH 33 DEGREES OF TIMING WITH AN AFR OF 12 TO 1 AND WE GET 270 HP ON THE BEST PULL.
WE DECIDE TO DO A TEST WITH OUR 9 TO 1 COMPRESSION RATIO USING SOME 118 OCTANE LEADED RACE GAS. THE BEST PULL IS 490 HP WITH 35 DEGREES OF TIMING AT 21 PSI. ON THE 7 TO 1 ENGINE, WE MANAGE 560 HP WITH 35 DEGREES OF TIMING AT 25PSI. TO GET TOTALLY STUPID, WE FIT SOME LARGER INJECTORS AND REMAP THE EFI SYSTEM FOR126 OCTANE METHANOL. AT 30PSI WE GET 700HP WITH 35 DEGREES OF TIMING!
WHILE ALL OF THESE FIGURES ARE HYPOTHETICAL, THEY ARE VERY REPRESENTATIVE OF THE GAINS TO BE HAD USING HIGH OCTANE FUEL. SIMPLY BY CHANGING FUEL WE TOOK THE 7 TO 1 ENGINE FROM 270 TO 700 HP.
FROM ALL OF THE CHANGES MADE, WE CAN DEDUCE THE EFFECT CERTAIN CHANGES ON HP;
RETARDING THE IGNITION TIMING ALLOWS SLIGHTLY MORE BOOST TO BE RUN AND GAIN OF 12.5%.
RICHENING THE MIXTURE ALLOWS SLIGHTLY MORE BOOST TO BE RUN FOR A SMALL HP GAIN HOWEVER, PAST ABOUT 11.5 TO 1 AFR MOST ENGINES WILL START TO LOSE POWER AND EVEN ENCOUNTER RICH MISFIRE.
LOWERING THE COMPRESSION RATIO ALLOWS MORE BOOST TO BE RUN WITH LESS RETARD FOR A SUBSTANTIAL HP GAIN.
INCREASING THE OCTANE RATING OF THE FUEL HAS A MASSIVE EFFECT ON MAXIMUM OBTAINABLE HP.
WE HAVE SEEN THAT THERE ARE LIMITS ON WHAT CAN BE DONE RUNNING PUMP GAS ON AN ENGINE WITH A RELATIVELY HIGH COMPRESSION RATIO. HIGH COMPRESSION ENGINES ARE THEREFORE POOR CANDIDATES FOR HIGH BOOST PRESSURES ON PUMP FUEL. ON HIGH OCTANE FUELS, THE COMPRESSION RATIO BECOMES RELATIVELY UNIMPORTANT. ULTIMATE HP LEVELS ON HIGH OCTANE FUEL ARE MAINLY DETERMINED BY THE PHYSICAL STRENGTH OF THE ENGINE. THIS WAS CLEARLY DEMONSTRATED IN THE TURBO FORMULA 1 ERA OF A DECADE AGO WHERE 1.5L ENGINES WERE PRODUCING UP TO 1100 HP AT 60PSI ON A WITCHES BREW OF AROMATICS. MOST FULLY PREPARED STREET ENGINES OF THIS DISPLACEMENT WOULD HAVE TROUBLE PRODUCING HALF OF THIS POWER FOR A SHORT TIME, EVEN WITH MANY RACING PARTS FITTED.
MOST FACTORY TURBOCHARGED ENGINES RELY ON A MIX OF RELATIVELY LOW COMPRESSION RATIOS, MILD BOOST AND A DOSE OF IGNITION RETARD UNDER BOOST TO AVOID DETONATION. POWER OUTPUTS ON THESE ENGINES ARE NOT STELLAR BUT THESE MOTORS CAN USUALLY BE SERIOUSLY THRASHED WITHOUT DAMAGE. TRYING TO EXCEED THE FACTORY OUTPUTS BY ANY APPRECIABLE MARGINS WITHOUT HIGHER OCTANE FUEL USUALLY RESULTS IN SOME TYPE OF ENGINE FAILURE. REMEMBER, THE FACTORY SPENT MANY MILLIONS ENGINEERING A REASONABLE COMPROMISE IN POWER, EMISSIONS, FUEL ECONOMY AND RELIABILITY FOR THE READILY AVAILABLE PUMP FUEL. DESPITE WHAT MANY PEOPLE THINK, THEY PROBABLY DON'T KNOW AS MUCH ABOUT THIS TOPIC AS THE ENGINEERS DO.
ONE LAST METHOD OF INCREASING POWER ON TURBO ENGINES RUNNING ON LOW OCTANE FUEL IS WATER INJECTION. THIS METHOD WAS EVALUATED SCIENTIFICALLY BY H. RICARDO IN THE 1930S ON A DYNO AND SHOWED CONSIDERABLE PROMISE. HE WAS ABLE TO DOUBLE POWER OUTPUT ON THE SAME FUEL WITH THE AID OF WATER INJECTION.
FIRST WIDESPREAD USE OF WATER INJECTION WAS IN WW2 ON SUPERCHARGED AND TURBOCHARGED AIRCRAFT ENGINES FOR TAKEOFF AND EMERGENCY POWER INCREASES. THE WATER WAS USUALLY MIXED WITH 50% METHANOL AND ENOUGH WAS ON HAND FOR 10-20 MINUTES USE. WATER/METHANOL INJECTION WAS WIDELY USED ON THE MIGHTY TURBO COMPOUND ENGINES OF THE '50S AND '60S BEFORE THE ADVENT OF THE JET ENGINE. IN THE AUTOMOTIVE WORLD, IT WAS USED IN THE '70S AND '80S WHEN TURBOS SUDDENLY BECAME COOL AGAIN AND WHERE EFI AND COMPUTER CONTROLLED IGNITIONS WERE STILL A BIT CRUDE. SOME FORMULA 1 TEAMS EXPERIMENTED WITH WATER INJECTION FOR QUALIFYING WITH SUCCESS UNTIL BANNED.
MY PERSONAL EXPERIENCE WITH WATER INJECTION IS CONSIDERABLE. I HAD SEVERAL TURBO CARS FITTED WITH IT. ONE 2.2-LITER CELICA WITH A RAJAY TURBO, WEBER CARB AND NO INTERCOOLER OR INTERNAL ENGINE MODS RAN 13.3 AT 103 ON STREET RUBBER ON PUMP GAS BACK IN 1987. THIS WAS ACCOMPLISHED AT 15PSI. WITH THE WATER INJECTION SWITCHED OFF, I COULD ONLY RUN ABOUT 5 PSI BEFORE THE ENGINE STARTED TO PING. I THINK YOU MIGHT SEE WATER INJECTION CONTROLLED BY MICROCHIPS, CATCH ON AGAIN IN THE COMING YEARS ON AFTERMARKET STREET TURBO INSTALLATIONS. IT WORKS.
Hedgemonkey
Member #: 360
What you want is fuel with the least amount of benzene in it (95) and then add 4cc of TEL and 2cc of methyl aniline. I think this gives about 120 octane which is about as much as you can get.
Tetraethyl lead comes from www.tetraboost.com and methyaniline comes from any lab suppliers, eg Aldrich. If you don't like paying tetraboost and have access to a chemist with glassware, email me for the recipe.
If you add it to MTBE (methyl tertiarybutyl ether) you can get 160 MON which I believe is the highest octane (performance number) fuel. Allows you to run about 40PSI, IIRC. Might get some of that from Aldrich, or a chemist with big buckets.
Edited by Hedgemonkey on 15th Mar, 2005.
Doodmeister
Member #: 149
Alberta, Canada
So is this 4cc of TEL and 2cc of meth anil to the gallon, litre, tank? or drum.
Disk full (/tmp/#sql_c9d4b_0.MAI); waiting for someone to free some space... (errno: 28 "No space left on device")
