Home > Technical Chat > Clutch arms
I have been looking at clutch arms like this, what are the thoughts pub ponts or not.
http://www.med-engineering.co.uk/catalogue...d-hd-clutch-arm
http://www.minispares.com/Product.aspx?ty=...id=42581&title=
and the forceracing Titanium Clutch Arm kit
The MED and Minispares items are the same I believe. Force on will prob be lighter *smiley*
i was thinking they was the same.
Edited by madmk1 on 21st Feb, 2011.
Chris Dillow
Member #: 6647
Avon Park Class B winner 2010/11
milton keynes
I brought a MED one about 2 years ago as i bent 2 std one's (don't ask) and got pissed off so i bought one, seems fine. But if your one is not bent i wouldn't bother.
been looking at the same tonight. I'm not bending them or snapping as I only use standard clutch spring, but I have just found out that the old heavy duty arm has worn a flat on the ball.. must have done less that 5k that was with plenty of copper grease?? I was cheap and have just ordered another. will probably regret it in 5k...
turbominij
Member #: 2104
Essex - UK
i went to one a year or so ago as i kept snapping the balls of the end of the standard one. Worth evey peny as since fitting this one i have not had one issue with the clutch arm.
Mine is a med kit and when i got it both places were out of stock and strangly enough both called me the same day to say they had some so im pritty sure they are the same. :)
Edited by turbominij on 22nd Feb, 2011.
"Tuning should be a compromise between what is possible and what is necessary"
10)Thou shalt always quest for more power
I was considering getting the MED kit above
Star Mag
Member #: 375
Leicestershire
I got the Med arm after the Northampton rollers event, bent three or four standard arms with my double grey. However it is a blatant rip off of Carls but my budget at the time did not run to one!
ministef1
Member #: 1791
Cranleigh, surrey
I had a force racing one after snaping 2 standard balls of the tip (painfull) always worked beautifully and weighed F all.....
"Cars are a lifetime of pain"
TM is full of sig worthy remarks at the moment*happy*
I was thinking that the force racing looks the nuts.
dischub
Member #: 8143
London
The MED and Minispares one is the same thing. I went for the MED arm after having shit loads of problems because of the normal clutch arms wearing too quick, bought one of the MED arms and it sorted all the probs.
Anyone had an issue using the med arm and the rod for the slave cylinder being too long?
I've had exactly the opposite, ended up having to get a longer push rod.
How long is your push rod?
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
" How long is your push rod? "
Ended up being me the wok wasnt fully home... It is now and the std length fits nice...
Custard
Member #: 8215
Rayleigh
Can this arm be used on a verto rts clutch?
Dave the Cake
No
welshdan
Member #: 1111
s wales
Running the minispares version without issues. As said its the same as the med item.
Minispares one for Xmas!
No idea how il fit it on the pickup'
Thanks dad! Hahahah
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
not had any problems with my grey and std arm i dono how much more pressure the double grey is over single?
altho a bent/cracked crank caused 2 throw out bearing to chew up and wreck the clutch cover thrust bit twice
now i know what that lack of and pulsing clutch and offset ware mark is on the pressure plate *frown*
