| Home > Help Needed / General Tech Chat > Rollcage integrity | |||||||
22nd Feb, 2011 at 11:17:07am
Last year I added the bar as shown to my rollcage, and am wondering whether it actually does anything to act against futher racking, as surely sufficient triangulation against racking will be present anyway due to the original diagonal.
Edited by minimole23 on 22nd Feb, 2011. On 7th Oct, 2010 5haneJ said:
180 Posts Member #: 373 Advanced Member Leeds |
22nd Feb, 2011 at 11:59:10am
I would get rid of the ones from the main hoop to wheel arch diagonal as i don't think they are doing anything.
"I'll get there in the end" |
22nd Feb, 2011 at 12:08:44pm
If you have passengers, use two diagonals. If only the driver, use one diagonal.
22nd Feb, 2011 at 12:15:46pm
Ive just this weekend added the diagonal i was speaking about. Its close to the back of my seat round my head as i like a far back seating position.
22nd Feb, 2011 at 12:28:59pm
I see the point about adding a brace to the main hoop, but my seat fouls it so couldn't The reason I added the braces from the b pillar to the rear legs is because I saw a crashed mini where the rear leg was all bent in, so thought I'd make it rigid. Though I may replace it for some 32mm tube as opposed to 38mm.
22nd Feb, 2011 at 12:32:42pm
It won't fall foul of the regs by adding bars, only removing them. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
22nd Feb, 2011 at 12:35:43pm
On 22nd Feb, 2011 wil_h said:
It won't fall foul of the regs by adding bars, only removing them. What about welding in a bolt in cage? To be honest its much stronger but you never know what they'll make of it. On 7th Oct, 2010 5haneJ said:
22nd Feb, 2011 at 12:58:02pm
You can weld a bolt in cage no problems just so long as you have the correct thickness plates welded to the floor pan under the rollcage feet. This applies to either weld in or bolt in iirc.
22nd Feb, 2011 at 01:03:22pm
On 22nd Feb, 2011 mini-sprite said:
You can weld a bolt in cage no problems just so long as you have the correct thickness plates welded to the floor pan under the rollcage feet. This applies to either weld in or bolt in iirc. Paul Oh bollocks, well I have no idea what thickness plate I welded in underneath, but as its covered by weld no one will ever know! On 7th Oct, 2010 5haneJ said:
22nd Feb, 2011 at 02:21:09pm
I dont see how any scrute could actually test what thickness you had put in either. Like you say the edges are covered with weld. "I'll get there in the end" |
22nd Feb, 2011 at 03:12:11pm
Well its nice to know with a few tweeks to the rest of the car I could take it hillclimbing then. I just kinda assumed I'd modified myself out the mod prod class with the safe but ghetto roll cage! On 7th Oct, 2010 5haneJ said:
22nd Mar, 2011 at 07:46:03pm
I've taken some time to consider whats what and decided to make the following tweeks, I did have many more ideas, but I really can't be arsed to hack the cage about anymore so going to do a simple removal or replacement procedure.
