| Home > Help Needed / General Tech Chat > 1275 metro turbo mini conversion | |||||||
6 Posts Member #: 9374 Junior Member birmingham |
22nd Feb, 2011 at 02:44:24pm
i have a problem with my engine it will run at tick over but will not respond when revving the car it will stay at tickover then will gain revs and cut out. i had the red top facet fuel pump and was advised to change it to the metro turbo fuel pump which i have done but the problem has stayed the same so its got nothing to do with the fuel.
22nd Feb, 2011 at 02:50:09pm
air leak? On 11th Feb, 2015 robert said:
22nd Feb, 2011 at 03:13:25pm
Ido you have a fuel pressure regulator - you should have the correct rising rate turbo one. If so what are your fuel line sizes for feed and return? On 7th Nov, 2011 apbellamy said:
