| Home > Help Needed / General Tech Chat > Will it fit. | |||||||
![]() 1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
23rd Feb, 2011 at 09:01:16am
Going to go to a breakers as I need an mpi pump for my project as I'm looking to run around 18-20 psi, will It fit straight into my spi tank with no mods? Or should I just get an even better one Honda etc? On 17th Feb, 2011 apbellamy said:
I popped my first one out the other day... |
23rd Feb, 2011 at 09:23:09am
23rd Feb, 2011 at 09:23:52am
Ok :) I'll get on it. Cheers wolfie. Edited by Rick.SPI on 23rd Feb, 2011. On 17th Feb, 2011 apbellamy said:
23rd Feb, 2011 at 09:32:21am
On 23rd Feb, 2011 wolfie said:
spi and mpi tanks are the same Not quite. The MPi tank is baffled and has loads of insulation type stuff on it. On 11th Feb, 2015 robert said:
23rd Feb, 2011 at 09:58:37am
but the pysical dimensions are the same for what rick needs Crystal Sound Audio said:
![]() 928 Posts Member #: 326 Post Whore bradford, west yorks |
23rd Feb, 2011 at 10:29:39am
Is the mpi tank heavier with the baffles? How much boost is safe to run with an spi pump? |
23rd Feb, 2011 at 10:49:00am
Spi pump runs to about 1.2-1.5 bar so unto just below a bar of boost. I'm fitting a ford puma fuel pump into my spi tank which is good for 6 bar of pressure - you can run what ever boost you like then. Just be sure all the fuel hose connections are good and tight !! On 7th Nov, 2011 apbellamy said:
23rd Feb, 2011 at 11:11:25am
I would run no more than 10psi with the spi pump tbh. If something is worth doing, it's worth doing half of. |
23rd Feb, 2011 at 11:34:30am
On 23rd Feb, 2011 pot_dan said:
Is the mpi tank heavier with the baffles? Yes On 11th Feb, 2015 robert said:
23rd Feb, 2011 at 12:25:54pm
Sorry for thread hijack and thanks for the answers! I need a new fuel pump then. |
23rd Feb, 2011 at 12:27:31pm
23rd Feb, 2011 at 12:49:46pm
loads. It will run a 3.5 bar fuel injection setup so should be fine for 45 psi of boost if my maths is good. On 11th Feb, 2015 robert said:
23rd Feb, 2011 at 12:52:41pm
24th Feb, 2011 at 09:04:52pm
I haven't really worked out how to do eBay links on iPhone. But here is the item number - 160516793803 -
24th Feb, 2011 at 09:07:53pm
Sounds good but I'm just going to get an mpi pump from a breaker will be alot cheaper and is proven. Cheers for the heads up tho :) On 17th Feb, 2011 apbellamy said:
24th Feb, 2011 at 09:10:01pm
I am also looking for options for my self rick. I don't know how many moos are in scrappys. I haven't seen one yet. I trust they are about though. |
24th Feb, 2011 at 09:13:34pm
There's a few people breaking minis on tmf I'll drop by them first, and after that I'll just hold out for one checking in different scrappies and breakers. Worst comes to worse I'll have to run low boost for a lol bit, doubt itl be a problem tho the amount I've got left to do before my cars running is long enough to source one :) On 17th Feb, 2011 apbellamy said:
