Home > Beginners Tech > Boost regulated fuel pressure
carl talbot
Member #: 1323
quick question
I'm looking for a fuel pressure regulator for a low boost [7-8psi ] supercharged set up
Is it necessary to use the pressure fed type regulator ?
I see a connection from the plenum for boost signal , can this be blanked and a std fuel regulator used on a low boost set up ?
Carl
ps . I don't expect more than 70-80 bhp , so no vast amounts of fuel required !
Edited by carl talbot on 26th Feb, 2011.
Ben H
Member #: 184
Melton Mowbray, Pie Country
Is this a blow through or suck through setup?
http://www.twin-turbo.co.uk
Blow through must have a boost referenced regulator.
Suck through does not require a boost reference.
But the same typical boost referenced can be used for either application. Just dont apply boost for the suck through setup.
carl talbot
Member #: 1323
cheers chaps
yes its a blow through 1172 sidevalve
