| Home > General Chat > Wondered why my brakes were pulling to the left... | |||||||
27th Feb, 2011 at 10:23:25am
Oops...
27th Feb, 2011 at 10:25:22am
That should be a locking nut, then it would not work loose.
27th Feb, 2011 at 10:29:15am
The car has just always been like that with things, when i bought it, there was one bolt holding the bellhousing engine mount to the subframe.... Edited by Carlzilla on 27th Feb, 2011. On 26th Jan, 2012 Tom Fenton said:
27th Feb, 2011 at 10:36:39am
On 27th Feb, 2011 Carlzilla said:
Also thought to myself that they should have been nylock nuts when i was changing the tie rods.. and you never thought to fit some? At least the big fat washer is still there. Seen so many that dont, just have the thin cup washer instead. Edited by Sprocket on 27th Feb, 2011. On 26th Oct, 2004 TurboDave16v said:
27th Feb, 2011 at 10:42:03am
Dont have any to hand Colin, only changed them yesterday. Ill have to get hold of some in the week. In fact my spare nut and bolt supply is very scarce.
27th Feb, 2011 at 10:44:57am
you found the problem before you visited the undergrowth so thats a result if nothing else
27th Feb, 2011 at 10:49:05am
Well, the last person to touch these wernt the previous owner, it was the fella who helped me do the 998 - 1275 engine swap. Although i trusted him, and i did check the engine mounts. ill have to check anything else that was undone in the process as some of you have suggested.
![]() 834 Posts Member #: 2017 Post Whore Warwick. |
27th Feb, 2011 at 10:56:06am
Nothing wrong with a bit of a spanner check every now n then, not as easy with the car on the floor rather than a ramp though. came across quite a few looseys checking things over David. |
27th Feb, 2011 at 11:13:18am
That should be a locking nut, then it would not work loose, ..... as tom says you could also place a little "shake proof" strength locktite on the threads as well to make sure
27th Feb, 2011 at 11:21:18am
on autograssers Ive seen castelated nuts and split pins used instead of nylocks On 28th Aug, 2011 Kean said:
27th Feb, 2011 at 03:27:58pm
Bottom arm pin decided it didnt want to stay in anymore today when i was about 5 mins away from home. The nut AND pin had no thread, they didnt look very clever. Luckily a mate lives 10 mins away and bought a new nut and pin down for me and 5 mins later i was back on my way. Very good job i wasnt doing anything more than about 30mph. Kinda shat myself.
27th Feb, 2011 at 03:40:05pm
For fucks sake, stop driving this car before you kill yourself or someone else.
27th Feb, 2011 at 03:40:58pm
Have you not learnt yet?? Check everything just get some spanners and sockets check the whole car matw before you get yourself killed Drives
![]() 257 Posts Member #: 7048 Senior Member Bridgend |
28th Feb, 2011 at 03:35:20am
Realy does sound like the whole car needs a spanner check, last time I did it too mine, a bottom arm locking nut was loose. Turbo parts collector at the moment, almost ready. |
