Home > Help Needed / General Tech Chat > Plenum Chamber Dilema
andyuk1275
Member #: 9276
Darlington north east
Hi Guys.
I bought this Plenum Chamber couple of months back, in the Description it says that its been modified for a dump valve, but iv'e just noticed everyone else seems to have the dump valve mod the other side of the plenum....
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...e=STRK:MEWAX:IT
can anyone help ?
thanks
Doesnt look much good if you want to run an intercooler, as some people cut the pipe off where the dump valve takeoff is on that one.
Which is what i will be doing at some point. Your probably best off getting one in the 'normal' position i think, unless youre not planning on running an intercooler.
andyuk1275
Member #: 9276
why cant i run an intercooler off this one ?
It makes no difference.
You could, but the pipework would be awkward as the plenum will be pointing down towards the turbo, instead of towards the front of the car
You won't be able to run an intercooler because the pipe is pointing the wrong way.
You could have it cut and re-welded.
andyuk1275
Member #: 9276
no worries lads. luckily i have acsess to a welder and pipe.
this has cleared up a few things. much appreciated as always !
This is what i shall be doing, not ideal, but no welding involved. Brings the intercooler pipework in a better place so theres less bends needed.
no welding involved? explain please as there does not seem enough inlet there for a hose to clamp on
rosco454
Member #: 5222
Northumberland
From the picture I reckon if you could get a hose on there it will blow off as soon as it gets a bit of pressure through it.
Cheers Ross.
http://www.turbo-mini.com/9629/56563.html
Cut and ground down smooth as per that i was thinking of. As i said not ideal, but im yet to come across somebody near me with the ability of making a tidy job of modifying it, as i havent an ounce of skill with a welder
Edited by Carlzilla on 27th Feb, 2011.
Wintersurfers is just chopped like this and its never popped off.
He's be running 10psi for the last 1000 or so miles.
man that is red lol
never seen that mod before
chinlesswonder
Member #: 1192
In the garage......again!!
I tried a plenum like that, kept blowing off, think coupe on here tried it also with the same problem, you may need to put a swage on the end or run a weld around the neck to give the hose some purchase.
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
wintersurferuk
Member #: 2208
thats about right, chopped it off just as it flares so when you clamp it theres more to hold on to. as for the dumpvale i just got a t-pice off ebay which fits in-line with intercooler
like this
http://cgi.ebay.co.uk/SILICONE-COUPLER-T-H...=item519599d5ff
madcatminis
Member #: 5327
Dudley, West mids
Hey carlzilla I'm only up the road from you as you already know. As it happens I'm an Aerospace Tig welder. *happy* Let me know if you need any stuff doing.
I was only running 10psi when mine was like that, but it was ok.
