| Home > Help Needed / General Tech Chat > Can\'t get reverse | |||||||
![]() 902 Posts Member #: 111 Post Whore Loughborough |
27th Feb, 2011 at 05:02:33pm
Hi guys,
![]() 558 Posts Member #: 8143 Post Whore London |
27th Feb, 2011 at 05:34:53pm
Pre verto or Verto? Check out the clutch adjustment |
27th Feb, 2011 at 05:35:55pm
I'd try a normal shifter if you have one mate, the quick shifts can be a pain in the arse if they get in the wrong position.
27th Feb, 2011 at 05:46:33pm
Its at verto clutch. Odd thing is nothing has changed since it was last driven.. Unortunatly I don't have a STD shifter to use.
28th Feb, 2011 at 07:11:45pm
Is it a proper KAD or a copy, i had a copy one and the little ball on the end kept dropping off. Does it swing across the gate when its lifted?, Have seen the underside of the gear selector with dents inwards preventing the shift from swinging across. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
28th Feb, 2011 at 08:41:48pm
the problem will lie with the cad contraption ........ i would ditch this and fit the original one ........much better
