| Home > Wanted > 52mm ID steel pipe section | |||||||
27th Feb, 2011 at 06:50:17pm
after trying to fit up the exhaust on the car yesterday, it turns out my system and downpipe have the same external diameter of 52mm so I'm looking for either a section of 52mm ID pipe approx 150mm long to make a sleeve.
27th Feb, 2011 at 06:52:36pm
You will find it tricky to find 2" internal, however what you can do is find a custom type exhaust place, and get them to stretch a bit of 2" OD pipe with pipe expanders so it is a nice sleeve fit. Then weld one side to your downpipe, the other stays as a sleeve fit to the system, bosh job done!
27th Feb, 2011 at 07:08:05pm
cheers Tom. there is a place in Prestwick I might try as the place in glasgow i would have used is now out of business |
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
2nd Mar, 2011 at 12:37:10pm
Or ask them if you can raid their old exhaust pipe skip and cut a piece off yourself.
2nd Mar, 2011 at 04:17:17pm
On the rusty jagged edges I suppose ?. |
3rd Mar, 2011 at 08:53:27am
all sorted - got a section from a local fabricator |
