Home > Technical Chat > not a turbo but hope you can help (head/piston help)
Big Mark
Member #: 454
ok, I just stripped the top off my engine and noticed the valve springs are double not single is this normal for 1275 A+?
Curious now if the head is standard, any tell tales to look for?
How can I tell if it has been modified for unleaded?
Just noticed the pistons are dished down and have a B stamped on the top, is that standard?
all comments and opinions welcome
SumpNut
Member #: 28
Looks fairly standard to me.
Whats the ports like in the head?
Dangerous
Member #: 417
Looks like a Mg head 1.4" inlets and double springs standard
The B you see on the top of the piston is to tell the guy that machined the bores what size tolerance to make them.
Looks like an MG Metro engine to me. Although I cannot remember if the MG metro engines had dished or flat top pistons?? Anyone??
MG i would say. 29-36 valves double springs & pistons with a shallow dish.
Phil. *smiley*
SumpNut
Member #: 28
My old MG metro engine (not turbo) had dished pistons
You guys sure the MG had double springs as standard? I know the 'cooper' didn't - but something is rattling in my brain telling me the MG didn't either???
Dangerous
Member #: 417
Mr haynes has
1.703 length for the inner
1.740 length for the outer
nutter driver
Member #: 47
Not very sunny swanage
afaik only the turbos had double valve springs...... im almost positive......
i know this is a really late reply, but im trying to catch up with well over 100 threds at the mo!!!
I'm sure the MG Metros did as well.........
Well the one I had for a bit did anyway!
Big Mark
Member #: 454
cheers guys
Looks 100% like I have an MG leaded motor.
Just to move on from the head, I am going to be uprating but not to over 105 bhp. is there any benefit to changing crank to a turbo one?
Mark
Nope
turbo crank (barr an early few) are identical to all other a+ 1275's *smiley*
dont need to rev turbos hard so crank/rods arent all that important
6232 is standard A+ crankshaft, 6581 is hardened "Turbo" crank.
Phil. *smiley*
Big Mark
Member #: 454
cheers guys
not many 6581 cranks about mind as they didnt use them much. most turbo's had the 6232
Iain - Early ones weren't the 6581 - this appeared sometime in '86 given metros that I've pulled apart - Prior to that was deffo the 6232.
This is what i've found at least - anyone know any different? Did your engine from a 1989 turbo have the 6581 for example???
D
ah i see *smiley* easily confused me!
end of the day a 6232 does the job nicely for all power levels.
im keeping to a min of 10thou undersize though, no more. i.e. just a reground std crank.
