| Home > Help Needed / General Tech Chat > double checking!! | |||||||
107 Posts Member #: 9276 Advanced Member Darlington north east |
28th Feb, 2011 at 04:49:27pm
Hi all. im just double checking that these pistons will fit in a 1275 block that im having bored out by +20 to make 1293.....
28th Feb, 2011 at 04:53:46pm
The block must be bored and honed to suit the pistons, not bore the block then buy the pistons. On 7th Oct, 2010 5haneJ said:
28th Feb, 2011 at 04:54:51pm
STOP!
28th Feb, 2011 at 04:54:54pm
yeh i'm buying the pistons now with all the other parts before it comes out the car mate :) |
28th Feb, 2011 at 10:05:28pm
come on guys i really need to know if these will fit ! |
28th Feb, 2011 at 10:08:19pm
What do you mean? If you bore a block 20 thou then hone to give whatever the specified piston to bore clearance is then yes they will fit.
28th Feb, 2011 at 10:10:11pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=8589 On 28th Aug, 2011 Kean said:
28th Feb, 2011 at 10:28:12pm
fooks sake. ill look at the omega equivlent.
28th Feb, 2011 at 10:34:06pm
with the omega's and accralites they sit down the bore a bit (about 40 thou?), some people run them down the bore but I always get the block decked so they come to the top, no where near what the JE's are though, they are just silly (unless they have changed them)
