Home > Help Needed / General Tech Chat > Thermostat blanking sleeve or not & Oil pressure switch questions.
Ok lads I have some bone questions to ask.
Q1. As my eng is dry decked will i need to put my sleeve back in or not
Q2. As you can see in the pic i have the oil feed at the end of the front and the oil pressure sender at the side will it work if i tap the bottom side out for the OE pressure switch. Or is it needed?
yep you can just tap a hole for the OE switch if you want the light,
the sleeve is a good question, I think yes you should use either a sleeve or a stat.
