| Home > Help Needed / General Tech Chat > Arrrrggghh!! flywheel removel | |||||||
173 Posts Member #: 9184 Advanced Member lancashire bolton |
1st Mar, 2011 at 08:21:48pm
Hi all
432 Posts Member #: 7856 Senior Member Essex |
1st Mar, 2011 at 08:36:13pm
Halfords sell a flywheel puller, as for heating, what is the reason for not wanting to? I have used a paintstripping gun in the past which has worked perfectly! |
1st Mar, 2011 at 08:38:46pm
If its a verto they can be a pain to get off, best is to get the puller on it (after you have fixed it) and put on as much pressure as you dare (without sticking a scaffold tube on the end and twisting off the head of the bolt) pour boiling water on it, tap it through the starter hole, dont stand in front of it if you value parts of your anatomy, leave it overnight with the puller still attached, i have seen them spring off on their own sometimes with a temperature drop.
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
1st Mar, 2011 at 08:40:38pm
make sure the puller is on square, turn the engine over by hand and make sure all of the three bolts that connect to the flywheel are done up the same amount, you don't want it on crooked.. I run a supercharger and I don't care the TB is on the wrong side.
1st Mar, 2011 at 08:40:53pm
Did you remove the washer? In the 13's at last!.. Just |
1st Mar, 2011 at 09:01:12pm
Had a job getting the flywheel of the van's engine.
1st Mar, 2011 at 09:03:07pm
On 1st Mar, 2011 chinlesswonder said:
If its a verto they can be a pain to get off, best is to get the puller on it (after you have fixed it) and put on as much pressure as you dare (without sticking a scaffold tube on the end and twisting off the head of the bolt) pour boiling water on it, tap it through the starter hole, dont stand in front of it if you value parts of your anatomy, leave it overnight with the puller still attached, i have seen them spring off on their own sometimes with a temperature drop. do not tap it through the starter hole thats how things get bent fit the puller up properly the three bolts wound all the way in then 1/4 turn back, little dash of oil on the main bolt wind it up steadily with force ( ie dont rag, rag, rag) imagine your doing up a head nut put as much torque into it as you dare then you want to hit the centre bolt square on with the heaviest hammer you have again dont tap tap tap one big smack should have it off with only 3 knuckles missing. mine was that stuck it took half the taper and Andy's well i broke his but we successfully removed a lovely flywheel another method i tried was to wind it right up as per the other and gentle heat on the main bolt between the flywheel and puller but when it popped it took the blowtorch with it across the garage almost, very dangerous Yes i moved to the darkside |
1st Mar, 2011 at 09:06:24pm
Also make sure the washers are in good condition. Mine are all bent now... On 11th Feb, 2015 robert said:
1st Mar, 2011 at 09:06:34pm
pft lol hope my mini is faster than i can type Yes i moved to the darkside |
1st Mar, 2011 at 09:58:37pm
cheers for the help fellas |
1st Mar, 2011 at 10:43:23pm
If its a verto they can be a pain to get off Minisport don't do Verto flywheels
1st Mar, 2011 at 10:49:16pm
On 1st Mar, 2011 sean g said:
Also questioning the quality of the puller (machine mart) so if anyone knows of a good place to get a pulley that would be great. I am not aware that Machine mart did a puller for the A series flywheel. This might be the reason it has broken. In which case you need the correct tool, and has already been suggested, is available at Halfords. The correct puller usually takes a considerable force before anything fails, and then its usually the bolts that strip their threads rather than the puller itself. I've had mine for 20 years and its still going strong. On 26th Oct, 2004 TurboDave16v said:
1st Mar, 2011 at 10:54:11pm
Also,
Edited by Joe C on 1st Mar, 2011. On 28th Aug, 2011 Kean said:
![]() 1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
2nd Mar, 2011 at 12:43:58am
ive got my eye on that puller... On 17th Feb, 2011 apbellamy said:
I popped my first one out the other day... |
![]() 825 Posts Member #: 2208 Post Whore Essex |
2nd Mar, 2011 at 01:29:02am
lol thats what i thought, flashbacks!
On 1st Mar, 2011 theoneeyedlizard said:
Did you remove the washer? |
181 Posts Member #: 9072 Advanced Member Jersey, Channel Islands |
2nd Mar, 2011 at 01:52:33pm
I did mine recently and bought a puller from MiniSpares (http://www.minispares.com/Product.aspx?ty=pb&pid=36627&title=). I haven't used others before but this one worked for me and looked very well made for the job.
Edited by fasteddie84 on 2nd Mar, 2011. Speed doesn't kill, suddenly becoming stationary, now that's what'll get ya! |
2nd Mar, 2011 at 02:37:09pm
If the flywheel does not break free from the crank with a sharp crack and the flywheel wanting to jump at you, there is a strong chance the flywheel has welded to the crank caused by fretting Edited by Sprocket on 2nd Mar, 2011. On 26th Oct, 2004 TurboDave16v said:
2nd Mar, 2011 at 03:20:24pm
I have the KAD Flywheel Puller the best 100 quid I ever spent,
On 17th Feb, 2009 Rob H said:
2nd Mar, 2011 at 04:15:57pm
I,m just so pleased that all I have to do is undo 6 bolts and lift the flywheel off.
2nd Mar, 2011 at 06:55:31pm
I'll be honest and say that I think Isigonis was quite happy that the interference fit of a Morse taper was sufficient for an 850 or 998. I think he had second thoughts with the E series since it also uses the 6 bolts, but is still the same transfer gear arrangement.
2nd Mar, 2011 at 07:37:41pm
I know your right for a Fact Colin,
2nd Mar, 2011 at 08:49:26pm
ive got similar to the kad one but with a 10t hydraullic ram, i can see the flywheels wince when i get it out "Turbo's make torque, and torque makes fun"
2nd Mar, 2011 at 08:52:34pm
Me too! its the nuts!
On 2nd Mar, 2011 joeybaby83 said:
ive got similar to the kad one but with a 10t hydraullic ram, i can see the flywheels wince when i get it out On 28th Aug, 2011 Kean said:
