| Home > General Chat > engine detonation | |||||||
![]() 644 Posts Member #: 9371 Post Whore East Yorkshire |
2nd Mar, 2011 at 11:18:35am
Am I at risk running a standard NA 1275 engine with a turbo? I am only intending to run 3-4psi until i can afford to build a low compression monster. Also would fitting an intercooler help or hinder my fragile little 1275 with its annoying high compression?
BHP sells engines, but Torque wins races! |
2nd Mar, 2011 at 11:20:22am
If you can resist turning the boost up and keep your timing and mixture in check 4psi will be ok as long as your compression isn't something like 12:1 If something is worth doing, it's worth doing half of. |
2nd Mar, 2011 at 11:23:09am
what about the intercooler? also what are 1275cc engines from standard, aren't they about 11:1??? BHP sells engines, but Torque wins races! |
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
2nd Mar, 2011 at 11:29:27am
They are somewhere around 10:1 ish A+, and lower than that on non 's' a series. one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
2nd Mar, 2011 at 11:37:28am
Intercooler would be a good idea, keep the boost low and fueling and timing good then you shold be ok, I would probably use some higher octane fuel too, tesco do a good 99 octane Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
2nd Mar, 2011 at 12:00:55pm
On 2nd Mar, 2011 bennyy said:
tesco do a good 99 octane ![]() But it only lasts about 15minutes. I put some in van left it a week and it ran like crap till i filled it up with fresh. If something is worth doing, it's worth doing half of. |
2nd Mar, 2011 at 01:13:35pm
tesco do a good 99 octane ![]() What makes you think its actually good? other than it says it's 99 octane on the pump. If you have an expensive engine, or you aare pushing the boundaries of a standard engine in the manor suggested, Shell V power is the only fuel that should be used, not just because its 99 or 100 octane On 26th Oct, 2004 TurboDave16v said:
2nd Mar, 2011 at 01:32:41pm
yes IMO that boost and intercooler and tuned up correctly, it will be fine. Best 1/4 mile 13.2 seconds @116 mph
107 Posts Member #: 9276 Advanced Member Darlington north east |
2nd Mar, 2011 at 02:31:05pm
Have a look t turbo phils site. www.turbo-minis.com or .co.uk baasically everythings ok for low boost apart from the pistons... But as everyone else said they might be ok... |
2nd Mar, 2011 at 02:48:08pm
tesco do a good 99 octane ![]() What makes you think its actually good? other than it says it's 99 octane on the pump. If you have an expensive engine, or you aare pushing the boundaries of a standard engine in the manor suggested, Shell V power is the only fuel that should be used, not just because its 99 or 100 octane A fuels octane is a measurement of the ability to resist detonation, which occours when the fuel explodes rather than burning in a controlled manner. What makes you say shell v power is any better than any other higher octane fuel? Do you have any hard evidence? Or just that shell are a big company so must be good? Audi s4 b5 - 470bhp & 486ft lbs
2nd Mar, 2011 at 03:16:53pm
There is a Job I frequent. Shell Technology Center, where they run tests on different fuels and blends. The engine testing center has 16 dyno cells running various tests on various fuels, not just their own. I know the guys there pretty well. Shell gaurantee their 99 octane fuel to be 99 octane at the pump, when you put it in your car. Shell use dedicated tankers for all their fuels, one for VP one for unleaded, one for VP diesel and one for diesel. Tesco on the other hand use a tanker for petrol and a tanker for diesel. Tesco 99 is likely to be 1 or even 2 points down from advertised due to this fact as well as the deterioration by aging. Shell formulate their V Power so that is 100 octane so that by the time it reaches the pump, it is 99 octane, has strong anti aging addatives, uper cylinder lubricants and an excellent detergent package, which is why you pay that bit more than you would with tesco 99. Itys not just a price hike because its Shell.
2nd Mar, 2011 at 03:26:14pm
![]() 257 Posts Member #: 7048 Senior Member Bridgend |
2nd Mar, 2011 at 03:30:20pm
I don't know much about shell as there are no filling stations near me. But I run one of those cheap clear filters on my engine. I used BP all last summer and the filter inside stayed yellow, I came back to uni and used sainsburys fuel twice and now the filter is brown.
Turbo parts collector at the moment, almost ready. |
2nd Mar, 2011 at 03:31:57pm
I have to say I have had some really bad super from Tesco before, the car knocked like a bastard on it until I threw two bottles of booster in.
Edited by Tom Fenton on 2nd Mar, 2011.
2nd Mar, 2011 at 03:33:18pm
2nd Mar, 2011 at 03:44:10pm
2nd Mar, 2011 at 03:48:04pm
^ posh git. If something is worth doing, it's worth doing half of. |
2nd Mar, 2011 at 03:57:42pm
i have said it many times an intercooler is not the icing on the cake ...........ITS MORE CAKE!
2nd Mar, 2011 at 05:05:54pm
with regards to fuel, iv always led to believe the super market is poor quality fuel and always shell, bp or esso |
1083 Posts Member #: 8932 Post Whore |
2nd Mar, 2011 at 07:23:14pm
Thanks to Sprocket, thats good info. Suppose the least you can do when running a performance engine is to make sure the fuel your using is good. |
3rd Mar, 2011 at 07:51:20pm
Well i might try something extra special in a few years, if we're talking fuel then LPG has an octane rating of 114.. Spent many years working with propane, just like hank hill BHP sells engines, but Torque wins races! |
388 Posts Member #: 442 Senior Member Manchester |
3rd Mar, 2011 at 08:42:49pm
Doesnt LPG have a habbit of burning out valves if not properly set up? Not having the same lubrication properties as normal fuels.
3rd Mar, 2011 at 10:28:35pm
Robert is Tm's very own propane injection ex spurt :) On 26th Oct, 2004 TurboDave16v said:
![]() 1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
3rd Mar, 2011 at 11:38:12pm
I've always used shell in all my cars, mostly for convenience as there's 2 shell stations in thrapston alone, but I've always used good fuels where I can since my mums car got a problem using tesco fuel and had to have the fuel system cleaned out. Edited by Rick.SPI on 3rd Mar, 2011. On 17th Feb, 2011 apbellamy said:
I popped my first one out the other day... |
