Home > Help Needed / General Tech Chat > couple questions thread
1275City
Member #: 9392
right been reading for a couple of evenings but got a few questions
standard 1275 metro internals what psi and bhp can they take before things go bad
if not what pistons are good enough to take 140bhp+
hazpalmer
Member #: 9038
Carlisle, Cumbria
if you use the search function you should find lots of info. And a good piston a lot of people use is the cast omega (+20) with the 10cc dish
scott the joiner
Member #: 9229
newcastle upon tyne
how much over 140+bhp you after? & do you have a boost level you want to run? or does boost not matter as long as you get the desired power?
1275City
Member #: 9392
well i am hoping to make up a good 140-150bhp and that its only the boost restricting the power for example 10psi 130bhp 14psi 150-160 so its only a matter of uping the boost and i can get a bit more power
spec i am thinking of
lightened fly wheel
modified head
front mounted alloy IC
dump valve
straight cut drop gears
undercrown cooling jets
i am not sure on turbo as a gt17 is expensive in my opinion
i want the turbo to come in 3000rpm and hit hard!
Rick.SPI
Member #: 8027
Cross pin diff needed I'd say, but don't expect too much, I the engine isn't in tip top condition it isn't going to last long from the way you've explained you want it.
tadge44
Member #: 2500
Buckinghamshire
I wish I thought that I could get another 20-30hp by increasing boost by 4 psi -sadly I dont thinkk I can
scott the joiner
Member #: 9229
newcastle upon tyne
you will get 140-150 from std metro turbo pistons with the right modds to the head to lower compresion get it ported cam intercooler & you should see them figures not the 160 tho
wintersurferuk
Member #: 2208
you might want to think about a diff. another point to look at is the head and cam.
good head will go a long way, which you may need to change the cam to suit.
have a look at my build, started with a std 1275.
1275City
Member #: 9392
cross pin dif ok?
engine has only done 21k miles from new and had one old lady owner who was a friend of the family, engine has been serviced by my grandad from new
140bhp would be nice to be fair
mg N/a cam not ok?
just had a browse on intercoolers is it best to be short and fat or thick and thin?
Rick.SPI
Member #: 8027
whatever fits as long as it isnt a cheap chinese thing, if you want cheap youll get better quality coolers from various cars at the scrapper.
wintersurferuk
Member #: 2208
have a search on cams, theres a few different ones so do a bit of reading on them.
intercooler, whatever fits. read peoples build threds to see what there using and how there fitting them.
heads, speak to benross or turbo phil, there the head wizards on here.
diff, maybe try to get the minispaires x-diff as many people have used them and they do tend to hold out.
one thing i found very helpfull was reading everyones build threads, this will give you an idea of what has been tryed and tested, what will fit and what wont, head-cam-rockers-turbos and what power there getting out of them, they all work together.
Wait till you get that gt17 in there!
tadge44
Member #: 2500
Buckinghamshire
Not with this I wont !
Transparent A-series. Thats novel *smiley*
tadge44
Member #: 2500
Buckinghamshire
Eeny meeny miny mo which one , blue or gold ?
The one with the 16cc pistons in. *tongue*
1275City
Member #: 9392
what power can the standard 1275 put up with? with a IC and 10psi?
